Question about Denon Audio Players & Recorders
Denon pma 980r power transformer u/s what can i ujse instead
2 Suggested Answers
SOURCE: We have a Denon 980R
The contacts are dirty. I have solved this by rotating around - left and right - a number of times. In the end, however, you need to clean the contacts. I never managed to do this satisfactorily before it burned off somewhere else. Too bad, a very nice amp.
Posted on May 02, 2009
SOURCE: I have DENON amplifier PMA-980R It
I have this same problem, and I just found that one guy over at audiokarma has posted a thorough walk-thru with pictures. (You have to register to view the pictures)
http://www.audiokarma.org/forums/showthread.php?t=218030
Posted on Mar 30, 2010
Tip
Denon VPROT Problem.
I posted a question regarding a Denon RCD-M37 DAB, which after a repair to the sub power supply transformer, came up with VPROT after a few mins use. After very careful measurements I found that the -12Volt line coming from the power regulator board situated behind the mains transformer was measured at 10.5Volts. It is necessary to replace the LM7912 regulator. Whilst with this board out check soldering and all other components. Normal operation has now been restored. I hope this will help regards Paul R.
on May 08, 2015 | Denon Audio Players & Recorders
What Remote control is compaterble With denon intergrated amplifire pma-255uk
Denon is one possibility but I also have a One for All data sheet that shows a code for Denon.
Oct 10, 2014 | Audio Players & Recorders
Pma 701 manual
Try this site
http://www.eserviceinfo.com/index.php?what=search2&searchstring=denon+pma-701
Jun 12, 2014 | Audio Players & Recorders
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
The only safe way to do this us to connect the sub to one of the other speaker outputs using a "speaker selector" switch. For example, you would go out of the receivers left speaker output, into the selector switch then out of the selector switch into the sub and the left speaker. There really is no other way.
Cant get sound from my receiver and amp together
if you are hooking up 2 units to run together, take a pic of the back of both units, and post them here
Mar 06, 2013 | Denon Pma-520 Integrated Stereo Amp...
Main transformer voltage
Google the complete model number of your "amplituner" and see if a schematic is available from the parts suppliers or if a complete schematic is available from Denon..
Dec 26, 2012 | Denon AVR-1604 Receiver
We have a Denon 980R amp. The input selector switch has a mind of its own roaring all around the dial
Apr 16, 2008 | Denon Audio Players & Recorders
663 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
