Panasonic plasmam troubleshooting
Tv turns on the green light comes on then turn red blinks 2.
get a light in the right side for a second then the screen is dark
  • 2,071 Answers
The condition of your TV called power supply overcurrent shutdown that"s why you hear a click. The TV is going into a protection mode to prevent further circuit damage. That's why it will not turn on or not powering up. I would concentrate on the power supply section board. Bad regulation of the incoming voltage could caused this issue although,there is a capacitor across the incoming line and nuetral.Maybe its leak or dry up and cause the problems,change it out with one of identical rating . Although now you are getting into dangerous area,especially if you have no electronic experience background. It could be also be a loose ,crack or cold solder joint,a blown fuse,fusible links or other component .It could be one of several boards.Unfortunately the level of sophistication on these TV make it virtually impossible to diagnose them further without taking them apart and probing around with a multimeter and other tools.This TV is handy enough to take to a repair shop find a good one.You will probably have to pay $75 to $100....
Hope this may help you..
Posted on Oct 10, 2008
I have a 56 in hdtv Panasonic tv will not come on green light flashes 20 times then goes to red. Help, on disability fixed income & cant afford to get repair or new tv. Please help, as soon as poss
Panasonic Plasma TV Repair - Understanding 14 Blink ...
? 8:35
Sep 26, 2014 - Uploaded by
Panasonic Plasma 14 Blink Code Explained with Repair Info How to ... I guess I'll try the SC board and if that does not work simply save up for a new ... The red power led was flashing 12 timespause a few seconds then flash 12 again. ... It powers up and shows the green power light is on, but there's no ...
The power light keeps flashing and the tv wont turn on - TV ...
Oct 24, 2015 - More about : power light flashing wont turn ... December 20, 2013 10:12:55 AM ... sound like it is coming on then it shuts off and the red power light flashes slowly. ... 50in Plasma tv power light is flashing 8 times and won't turn on. to come on bcause the power button keep blinking my tv will not come on.
Nov 06, 2015 | Panasonic Televison & Video
I am currently working on a Sharp Lc37sb24u. I was originally thinking it had a bad inverter board but now I am not so sure. When I turn the tv on the picture comes up with audio for about 2 seconds the...
Did you check the service manual troubleshooting guide yet. You can try disconnecting the power to the inverter board and see if it will stay on and have sound.
Service manuals:
Basic LCD monitor and TV troubleshooting guide:
Failed TV and Monitors pictures:
Learn about bad caps:
Capacitors kit: he can make you a set of caps for you.
Or just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Oct 27, 2011 | Sharp LC37SB24U 37 in. LCD TV
Red/green lights both blink and tv will on turn on
Are the red and green lights blinking at the same rate or not? If the green light is blinking every 3 seconds and the red light is blinking every 1/2 second, the lamp door is not properly secured. If both lights are blinking at 1 second intervals, try replacing the lamp. If a new lamp doesn't solve the problem, the TV needs service.
I hope this helps.
Jun 23, 2011 | Toshiba 52HM95 52" HDTV Projection...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The Power Light is Red
yeah, should stay red when unit is turned off, indicating there's power but it's doing nothing.
Per user manual:
Solid red - power off (standby mode)
blinking red - power off (now cooling)
blinking green - power on (preparing to light lamp)
solid green - power on
Mar 08, 2009 | Panasonic PT-40LC12 40" Rear Projection...
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Feb 12, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
The tv wont turn on
hello 2 blinks on this tv means you have this issue below
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
Dec 14, 2008 | Panasonic PT-44LCX65 Television
Panasonic pt-52lxc66 power light blinks
There are actually two red leds present on your tv and depending on which one is flashing is going to tell you what to replace. 3X on the Temp led will point to a faulty thermistor and you would want to replace this part. If the 3 red blinks are the lamp light than this is a error on the iris position and you would need to have the optical block replaced.
Feb 09, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
