Question about Freezers
Kelvinator Chest Freezer will not cool after spray painting rust spot.
I have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
Mike H.
  • Anonymous Mar 18, 2009
    My chest freezer is working well, however, is getting rust marks in it from things hitting the interior. What kind of paint or what can I use to cover these rust spots?
  • 750 Answers
Dear Landport2
Welcome to the site,
You said, you have a Kelvinator chest freezer, model number CFS101SM1W. This freezer is in excellent condition and was working ok. I notice that there was a rust spot on the bottom area so I decided to spray paint the entire inside with the appropriate appliance spray paint. After spray painting the freezer will not cool.
How old was your freezer?
This must be an ancient freezer!
And Unfortunately I was not able to tell you to leave it alone and not to turn it off!
You did not cause this!
Unfortunately it was so old that it probably was already on it's last legs.
Here is an interesting report I just read!
Repair or replace your appliances?
When to pull the plug on your old freezer
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model ?
The answer depends mostly on the age of your ,freezer
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your refrigerator is under warranty or less than four years old freezers),
paying for a repair makes sense.
Note that freezer under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your freezer is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new freezer.
Data also shows that it doesn't pay to fix a less-expensive freezer
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a freezer you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please do not for get to give a rating before you sign off!
Thank You, HUUUM
Posted on Oct 10, 2008
Clicks on an off
If it makes a clicking sound every few minutes and is not cooling.... Replace the start device on the compressor Kelvinator Freezer Start Relay 216594300 or possibly a URCO410.
Apr 19, 2016 | Kelvinator 12 cu. ft. / 340 liter Chest...
What is the size of Kelvinator chest freezer?
as kelvinator use a model number to denote size I would suggest that it is a 200 ltr freezer
Call a kelvinator service repair centre and they will tell you what size it is.
Jun 26, 2014 | Kelvinator Freezers
I have old tappan chest freezer. Have not used in three years. Cleaned out the mold and dirt however, paint is bubbling and has a few rust places. Can I paint the inside and if so what type would I use...
you might want to plug it in first and see if it still cools. If it has rust, you might have a compromised sealed system, in which case you have no refrigerant. Furthermore, Im not sure painting the inside would be a good idea, as the inside my always smell like paint, and therefore so would your food.
Sep 27, 2010 | Freezers
We were given a fairly new chest freezer (a smaller-med size) however it has some rust damage on the corners and expecially on the bottom. Can I paint over this? What should I use? Thanks!
Go to the hardware store and get some rust removing jelly. Sand the area with emery cloth and then prime the area and paint it with an appliance spray paint that matches your color
Apr 16, 2009 | Freezers
Temp
jtcarlier
20 Degrees is good
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator freezer is not freezing!
you mean it cools but not as afreezer ok, rework again the system properly vaccum and slowly charge it but please watch out the proper amperage of the compressor or might be the compressor motor now is weak, how old this unit,sir.thankyou
Aug 05, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kelvinator novelties chest freezer
check the defrost timer, defrost limit, and defrost heater.
Apr 21, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Rust On Bottom Of Chest Freezer
id sand it paint it with white rustolm and go from there and no it couldn't there is a layer of foam between the bottom of the outside and in side
Feb 11, 2008 | Freezers
Freezers Logo
1,616 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
