Question about Compaq Presario 700 470024-192 Notebook
FTP server problem
I am currently running an FTP server on my computer but I can't seem to access it when I am at work.
Any help?
  • 34 Answers
Go to Start -> Control Panel -> Windows Firewall then go to exceptions, add port, and use FTP for the name and 21 for the number.
Posted on Oct 10, 2008
What software should I use to bypass my university internet restrictions?
If the games are in fact, "yours" then you can configure your game server to publish on the normal HTTP port (80). Then, you will have no trouble at all.
I hope this is helpful,
--Robert
Oct 29, 2014 | Computers & Internet
Tip
How to access your home PC files remotely
There are a couple of ways of doing this. Here are a couple of my favourites. All of these require you keep your computer on.
1. Opera Unite
If you install the freeware browser Opera, then create an account with them, you can start Opera Unite, an online service for accessing files and services from anywhere. After you have added the File Sharing application from the Unite sidebar, you can configure the application. Choose to add a share location and choose your main hard drive (generally C:). Then, change your password and make sure that you set your Opera Unite account to private and check that File Sharing is password-protected. Then simply navigate to the URL that Opera provides (generally username.operaunite.com), enter your username and password and then you'll have full access to your files. Note that you will need to keep Opera running on your Computer
2. FTP server. *Only recommended for advanced users
By running a FTP server software like FileZilla on your home computer, you can create a far more powerful file sharing experience. Now, first up, you should go to DynDNS.com, sign up for a free account and then create a Dynamic DNS host. Next, download and install the DynDNS Updater and run on your computer. Now, to access the files that you have configured with your FTP server software, simply use your DynDNS hostname that you created in the sign-in process into Windows Explorer or Internet Explorer (or any browser) with the ftp:// prefix instead of http://. However, if your computer is on a home network behind a router, you will need to configure that also. Set up a port forward (generally Port 20,21, and 23) to the computer running the FTP server. The other advantage to this is that by finding out the server's local IP address (open Run, then type cmd, then type ipconfig, and write down the IP address shown) you can also access the files from the server within your network, simplifying the file access process greatly.
3. Orb 2.0
This is one of the slickest and smoothest methods. Simply download and install the Orb desktop client from Orb.com (also create an account and enter your details into the Orb client), then add any folders you want to share. Then, allow some time for it to index your content. Now, from outside your network, log in to Orb.com with the account you created and click on the Applications button at the top of screen. If you want the music, videos, photos or documents you specified in the setup process, choose the appropriate application, or choose File Sharing to access all of your files at once. Simply navigate the folders as if it was your local computer and you will be able to use them flawlessly. You can even access other physical drives like your CD drive online.
4. TeamViewer
This is a brilliant VNC replacement application. Simply create an account, then install the client on your computer. Also, enter your account details into the client (click the button at the bottom right of screen) and write down your 12-digit ID and password. From here, you have several options remotely. I recommend that you should link up your account first. Navigate to login.teamviewer.com and login, then add a client using the ID and password from your computer. Now, whenever you login to your account, you wont have to remember your ID/password. You can install the client on another computer and connect with your account directly or login to teamviewer.com and use the Java-based applet to connect and use your computer as if you were in front of it.
These should work well when accessing your files.
on Apr 22, 2010 | Computers & Internet
Cannot access FTP server from outside.
your server need to connect on Internet with pubilc IP or fixed NAT with public IP
Apr 08, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Cannot FTP at all behind Thomson tg585v7
Hi, your router will by default block all incoming packets from outside. You need to configure a firewall rule to allow tcp port 20 and 21 from outside and specify that it must be sent to the IP address of the pc running the FTP server software. Also make sure that your FTP server and firewall on the pc allows these ports in by checking your firewall on your pc.
Oct 10, 2009 | Computers & Internet
I want to create a ftp server in my internet . i create an ftp server by using serve-u but it only open in my lan.i gave my external ip adress but it does not open out side of my lan.plz help to create...
I use HFS its something called a http file server, its really useful, i use it to transfer files from my pc to my ps3, instructions come with it and its really easy to use
http://www.rejetto.com/hfs/?f=dle
You don't need to install, just run the .exe file, once the window opens just drag the files you want into the window
to access the files from another pc or device just put your specific ip into the addrss bar i.e http://192.68.2.198
Jul 04, 2009 | Microsoft Windows XP Professional SP2 Full...
How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to 192.168.0.102 from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be 192.168.0.102, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to 192.168.0.102. To access the external side of the router you need to go to 70.55.84.233 (according to the image you posted)
Jan 03, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Ftp server
What is the name of the software? Is that an FTP software?
Anyway if you are using DX-E401 Router you can enable DMZ (demilitarized zone) to your PC.
1.access your router configuration page (default ip: 192.168.0.1)
2.go to advanced tab
3.select DMZ
4.select enable then type the ip address of your server pc
5.apply settings
after that have someone try to access the files in your pc.
if the software you installed is ftp software then have them access it by this
ftp://internet_ip
the "internet ip" is the ip address found in the STATUS TAB of your router under the WAN catergory.
If this software you mentioned is using any particular application ports, you will have to open those ports for your server PC.
In that case you will to configure VIRTUAL SERVER. It's the actual term used by dynex. for you to have a general idea how to configure your pc behind your router please go to this link
http://www.dynexproducts.com/skins/skin_1/Topics/Documents/DX-E401_Manual.pdf
Virtual server configuration is in pages 22-23. It has detailed explanation of the terms used.
Hope this helps!
May 07, 2008 | Dynex DX-E401 Router
FTP Server configuration
GO HTTP://192.168.1.254/TECH PASSWORD ADMIN AND YOU CAN RESET EVERYTHING ON YOUR ROUTER WHAT EVER YOU WANT I HAVE SAME ROUTER BUT UPGRADED
Jan 22, 2008 | 2wire HomePortal 1800HG Router...
Sonicwall Pro 300 DMZ Problem
If you're within a network and try connecting to computers on it with the WAN public IP, it simply won't work - you must use the network IP. On an external Internet connection, it should connect fine to the public IP. If you have access to an external machine (remote desktop), or if you know of an FTP proxy, you can try it that way. I also believe http://www.webftp.co.uk/ a web based FTP client would act as somewhat of a proxy, you could try that with the public IP and see how you go.
Aug 09, 2007 | SonicWALL PRO 300 Firewall
Why won´t my FTP Client work with my D-Link router?
Make sure your FTP client software is set to passive. For security reasons the D-Link router does not deal with an active FTP client. An active FTP client can allow a hacker masquerading as an FTP server to gain access to your computer. Please contact your FTP client software manufacturer to determine how to configure the client for passive rather than active. Note: You will not be able to use an active connection through most NAT routers.
Feb 16, 2006 | D-Link Express EtherNetwork DI-604 Router
Compaq Presario 700 470024-192 Notebook Logo
96 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
