No control over magnavox tv
Can't turn tv on or off except by unplugging it. Then we have no control - cannot change channel or volume and menu button doesn't work. When on it seems like a commercial:
"Why your next tv should be this one" comes on the screen and then goes through a description of every menu feature. Do not have original remote control.
  • smokeater023 Jan 06, 2009
    Cannot turn tv off unless unplugging it and remote doesn't work and after power outage an F appeared in upper right corner....Poer On and Off button doesn't do the trick
  • Anonymous May 17, 2009
    I have the same problem with the original remote. Next?!?
    Champion:
  • 252 Answers
You need an original remote to fix that problem
Posted on Oct 10, 2008
Controls not working onDaytek TV, 40 in LCD,
yes, look carefully in the manual as I think it has a lock out feature that will lock out both keyboard on set and remote except for on off features.
Jun 13, 2012 | Televison & Video
I have problem with our Magnavox TR2510C101. My toddler press everything and now it turns out there is black screen (square) cover the image. Do you know how to fix it? thanks!
You have accidentally gotten the Closed Caption turned on....
Here is how to turn it off....
1) Press the MENU button either on the front of the TV or on the original TV remote.
2) Use the Volume + or Volume - to highlight "SET"
3) Use Channel - or Channel + to highlight "CLOSED CAPTION"
4) Press Volume + to access the CLOSED CAPTION menu.
5) Press Channel - or Channel + until OFF is highlighted.
6) Press Volume + or Volume - to confirm selection.
7) Press the TV/AV/EXIT button on the remote to exit or the MENU button on the front of the TV.
GOOD LUCK and please rate this solution...
Jan 14, 2010 | Philips Magnavox 27MS343S 27" TV
All buttons control tv/video, remote stopped working
Unplugged it for an hour.... buttons changed.....Unplugged it for four hours and everything worked......Left it plugged in overnight and back to original problem....
Oct 02, 2009 | Toshiba 32A33 32" TV
My digital comcast remote will do everything except change the channel on my magnavox TV. Volume/power control is fine. How can I fix it?
your tv needs to stay on the same channel for the cable box to work with the tv and you change the channel on the cable box not directly on the tv
Jun 12, 2009 | Philips Magnavox 20MC4304 20 in....
Black Box appearing on my screen
go into your menu and access the closed caption modes. someone has accidently put your tv in the "text" mode. turning off the closed caption feature will correct this.
Apr 01, 2009 | Televison & Video
STB with Magnavox remote (need codes) - Samsung #TXK2766
Did extensive checking and finally found out that the remote for Magnavox TB100MW9 analog/digital converter is not made for volume control. The channel changing buttons are half-way operable--sometimes yes, sometimes no--and to think they call this a remote! Therefore you must keep the other TV ready remote that you have been using (tape them together probably) for volume and mostly channel change. I know what Magnavox can do with these remotes - and you know how much more Magnavox I will be buying in the future. Nada, none,---from a very disappointed, frustrated customer.
Feb 12, 2009 | Samsung TXG2746 27" TV
Remote and caption problems
have you programmed the remote? or you can go into the menu button on the front of the tv, use the up down (either the volume or channel may move the selection) to locate the caption on/off control and turn it off that way. if you need the manual try here
http://tv.manualsonline.com/manuals/mfg/philips/19_inch_color_tv_cover_l9_pr1903c1.html
Dec 02, 2008 | Philips Magnavox Learning Universal Remote
unplug the set for a while , but this problem will return because of a malfunction in the EPROM CHIP , this controls the menu and a few other functions
Oct 17, 2008 | Philips Magnavox 27MS343S 27" TV
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Menu will not display
If the channel and volume visual display was not set up on the menu to display on screen , neither will show up even if either the remote or set front button are used. Make sure that the tv button is selected on the remote to access the menu .If that does not work ,then either the batteries are dead or the remote is dead.If it is you will need a new remote,sadly. Then you can press the m button , select sound and then select "display volume" and check "during adjustment". The channel display settings are found on "features" from the main menu. Hope this helps.
May 30, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
