Question about Electronics - Others
Baldor Motor Wiring problem
I am trying to replace the start and run capacitors for a grain bin fan. The old parts were taken out and wires removed before I became involved so I don't know how to connect the new parts. The wiring diagram which was in the unit is very old & worn- I've tried to make a photo copy and mark in the info which was worn off. I believe the appropriate diagram is the one in the center.
There are two start capacitors which are 216-259 microfarads. (They are the black cyclindrical looking items in the photo). The run capacitors are 20 micro farads. (They are the oblong silver colored items in the photo.)
I don’t understand physically how these are connected. I tried several scenarios and the motor just hums.
Please help. (If the photos didn't get attached because they are too large, please give me an e-mail address where I can send them. Thanks so much
  • Anonymous Mar 29, 2009
  • Craig Butler
    Craig Butler May 11, 2010
    Many questions here. How many leads? Are they numbered? Is there any name plate info? I can help but you must look at what you have ...good info on the caps...keep going.
  • 143 Answers
SOURCE: Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Posted on Jul 22, 2008
  • 254 Answers
SOURCE: HELP!!! Help wiring new motor for CKL60-1
  1. This is what your wiring should look like if you are using two caps. then you should be using a potential relay as well. This is the diagram for using a potential relay. Hope it helps you.
Posted on Aug 28, 2008
  • 157 Answers
SOURCE: wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Posted on Nov 12, 2008
  • 257 Answers
SOURCE: older sears bench grinder wont run 1/3 hp model 397 19581
Hi again, OK, Well since I don't have a wiring diagram and the colors don't help. I am also going to assume it is 110VAC. The larger wires are probably the run or primary, it you remember which ones were connected it will help with polarizing. ( getting it to run in the right direction as well as the start and primary working together). You can use the two terminal switch but you should use a three wire cord. Use the switch to break the neutral and ground the case. The connections should be as follows: Connection 1, would have one of the primaries and one of the starts to neutral. Connection 2, the other start to the relay. Connection 3, the coil side of the relay to the remaining primary. ( if the relay has two connections on one end and one on the other it would be the single) Connection 4, the 3rd position on the relay to hot. That is how a split phase is wired. You may find a simple wiring diagram on the net if you type split phase motor wiring diagram. Good Luck to you, this should Fixya!
Posted on Mar 04, 2009
  • 8 Answers
SOURCE: pool motor wiring
First and foremost, you need to check the Motor's voltage requirements, and match it to the voltage of the GFI you have connected to the House current.
The best way to do this is to use a volt meter at the GFI receptacle. Although it's likely the voltage at your GFI receptacle is 120Volts AC, you shouldn't guess on this. If you know what circuit breaker this GFI is using to get power.... you may be able to determine the GFI's voltage if you know how to distinquish between a single pole breaker and a two pole breaker (120Volts is derived from a sigle pole breaker, 240volts from a two pole breaker-which is twice the size of a single pole breaker).
Now the Motor: Most common Pool Motors are dual winding motors, on which, the voltage requirement could be changed to match the voltage supplied. On such a motor, there's a compartment where the cord is attached. Within this compartment, there's a configuration of screws or terminal points, and a related schematic which depicts the proper connections for each of the voltage options. By following these schematics, you will know how to connect the motor based on the available voltage supplied by your GFI protected receptacle.
Posted on Mar 23, 2009
Wiring- Connecting wiring on replaced fan motor
Your new fan motor should have a diagram with it or at least printed on the side of the motor, that will help a lot from your end. As for me, I don't know what unit you have, so I will try to help you with just the basics.
Your old motor probably had 3 wires. One went to the contactor, that is the "Line Voltage", one went to the Common terminal on the old capacitor (COM), that's the other "Line Voltage" wire, and the last one went to the "FAN" terminal on the old capacitor. The reason the old capacitor looks different is because it works for both the compressor and the fan motor (split capacitor). You still need this hooked up for the compressor to work.
The new fan motor.
These vary in brands and wiring so I can not tell you the colors without knowing exactly which motor you have. On the new motor wiring diagram, you should see the "Line Voltage" as described above that 2 of the wires are ran to each other (just on the diagram, not wired together on the unit). This is your power wire that goes to the contactor on the unit, usually black, and your Common wire that runs to the capacitor. You can still run this wire (COM) to the common terminal on the old capacitor since you still have to use the old capacitor for the compressor and the common terminal should still be jumper-ed from the contactor to the (COM) terminal. Then you will probably have 2 wires for the new capacitor, usually Brown and Brown/White. These wires run to each side of the new capacitor and doesn't matter which terminal. Then you will take a new jumper wire from the (COM) terminal on the old capacitor to the terminal on the new capacitor that has your Brown/White lead. Make sure you secure the capacitors inside the unit so not to touch anything surrounding them. Your new motor might also be a "Reversible" motor that has reversing wires also. Again, your new motor diagram can tell you how to hook these up. You have to have it spinning the right way, most of the time it is CCW (counter-clockwise).
I'm sorry I can't be any clearer on this, but without knowing the brands, models, etc, I'm in the dark. If you need any additional help, I would be glad to help! Good luck and hope you get to cooler days!
Jun 28, 2012 | Heating & Cooling
My condenser fan is running backward
An abrupt cycle of power can cause a motor to run backwards. If you turn the power off again and wait 10 seconds or so (enough for blade to stop spinning) it should run the right way. Put the capacitor back the other way and try again.
Apr 23, 2017 | Heating & Cooling
I have a 1022w bench grinder with a missing capacitor. The baldor catalog doesn't list the part number or spec for the cap. Nor is there a wiring diagram that shows the connections to the cap. Anyone...
Thats number the neccesary part for your grinder 12 mfd think about a fitting size of the capacitor and model if you will know for sure here is the information to get .
Jun 15, 2017 | Baldor 1022w 10" Bench Grinder, 1 Hp,...
Blower doesnt come on,exhaust fan comes on,burner lights,but no blower,already tried the cheap route and replaced the wall mounted thermostat,need a trouble shooting manual
Hi, W/D here.
Two things jump out at me. The motor start capacitor and the motor itself.
The capacitor gives the motor that kick that it needs to start. If you can hear the motor hum, but not rotate, it just might be the capacitor.
If it is the motor proper, changing the capacitor wont cure it. There are many reasons that a motor can fail, the most common being problems with the windings and bearing failure.
If you are doing this on the cheap, try replacing the capacitor. If this saves you, fine. But be prepared to replace the motor as well. If you have excessive play in the motor shaft when you push it in and pill it out, or feel difficulty when trying to spin the fan by hand (with the breaker tripped off, of course), then the motor would be suspect. Never change the motor without also changing the capacitor as well.
I recently (yesterday) changed a motor and capacitor for the same reasons. The cost of a selectable speed (low/medium/high) motor, capacitor, and packet of crimp-on terminals came to $109.00
You can troubleshoot your motor in place, but will need to remove the motor/fan housing to replace the motor if this is the issue. Usually, the housing fits into slide tabs and is held in place by bolts (2) at the front of the housing. You disconnect the wiring, remove the bolts, tip the housing down enough to clear the cabinet and slide it out. The motor is usually removed by loosening the bolt that holds the fan to the motor shaft, then loosening the clamp that holds the motor to the struts. Take your old motor and capacitor with you to your local appliance parts supply house for an exact replacement.
If you do replace the motor and capacitor, use tie wraps to secure the wiring to the struts that center and hold the motor in. This keeps the wiring tidy and keeps it from moving around, possibly causing the wiring to short.
Please let me know if I can help further.
Best regards, --W/D--
Jan 25, 2011 | Heating & Cooling
I m looking for a wiring diagram for an AC motors and how the capacitors are connected model baldor reliance part number fdl3612tm
Motor wiring- Capacitor usually gets two brown wires, 120 Volt Black= Power, White neutral.
220Volt usually no white Black =L1 Power, Red,Blue, Speeds. Yellow=L2
Nov 15, 2010 | Heating & Cooling
I have a Dometic 579 Series Brisk Air AC. The model Number is 57915.531. When I turn the fan on, nothing happens. If I reach up and turn the wheel blower the fan will start up and everything works. I...
My sheet shows part # 3100248.420 as fan run capacitor.You may have an updated number. Check voltage outputs labeled on it are same as on old one, and double check wiring is correct, to and from capacitor. Be careful not to mistake compressor start capacitor as well. By sounds of number, it's probably the right one.
May 27, 2010 | Dometic Rooftop RV Air Conditioner
How do I wire a new condensor fan motor to the new capacitor? The old capacitor is longer and it has 3 terminals. the new capacitor is much smaller and oval. It has 2 terminals. the fan motor has 3 wires,...
Before attempting any of these recommendations, First disconnect all the power sources and check your wiring diagrams on the motor and condensing unit.
On the old capacitor if you look on the top near each of the three terminals. Are they marked, fan - C - herm? If they are that is a dual capacitor and that needs to stay because that is also your compressor capacitor.
The Red wire from the conductor is Run and it's connected to C on the old capacitor.
Follow the Yellow wire and see if it goes to the S or start terminal on the compressor, if it does then that is the Start wire for your compressor and it connects to herm on the capacitor.
For the fan motor a lot of times the wiring connections are printed on the motor label.
Check the label, Purple should be run and connect to C on the old capacitor.
Black should be Common and it connects to the opposite side of the contactor as the Red wire. If the Red wire connects to T1 then the Black wire connects to T2.
The Brown wire shoud be the start wire on the fan motor and it connects to the Fan terminal on the old capacitor.
Now if you want to use the new fan capacitor. Take the Purple wire from the motor and look for any marks (red paint or a dash) on or beside the terminals on the new capacitor. If there is an identifying mark then connect the Purple wire to that terminal, if no marks you can connect it to either terminal. Then you need a jumper wire from C on the old capacitor to the purple side of the new capacitor. Then take the brown wire and connect it to opposite terminal of the new capacitor.
Apr 05, 2010 | Heating & Cooling
I have a Trane XE1200 condensor for which I bought a replacement fan motor, same specs as the original G.E. motor. The original G.E. motor was wired to a dual capacitor, which is also wired to the...
OK, locate the terminals on the capacitor marked "HERM"(Compressor lead), "FAN", and "COM".(common)
HERM and COM remian as they are.
The wire going to "FAN" (usually brown) will be placed on either terminal of the new capacitor. (This is the ((usually brown)) wire comming off of the fan motor.) An additional wire needs to be run from the other terminal of the new capacitor to the "COM" on the old capacior.
What you are doing is bypassing the fan side of the old capacitor but still using the compressor side of the old Cap.
The fan should have a wiring diagram on it to help identify the wires if there is no brown wire. The other two wires will be identified on the wiring diagram as well, but one typically goes to the contactor and the other to the board.
Sep 07, 2009 | Heating & Cooling
Blowing hot air fan not turning outside making a humming noise
Replace the run capacitor. It is a silver cylindrical object located in the electical compartment of you outside unit. There is most likely three places on the top where different color wires are attached. One is marked F,or Fan. The center should be marked C, or Common, and the last should be marked Herm, with wiring to the compressor. Make sure you write down or label each wire you remove and it's correct location. They must be installed on the new part just like they were on the defective part. For you to know which dual run capacitor you need, the old one will have printed on the side either 370, or 440 v,as in volts. You must also need to know the microfarad rating and it is also printed on the side with the voltage rating. Since this is most likely a dual(runs fan and compressor) you should see two ratings abbreviated as mfd. Something like a 5mfd for the fan motor and perhaps a 35 mfd for the compressor. CAUTION !!! This device has line voltage and you must insure the power is off at the disconnect/ breaker BEFORE you begin the repair. Sounds complicated but really only takes a few minutes. The main thing is getting the right mfd and voltage ratings for the new part and keeping a record of where the wires were mounted on the old one, and putting them back the same place on the new part.
Jun 17, 2009 | Carrier 38CKC036 Air Conditioner
Fan does not work
Check resistance through the fuse and the actual control switch and see if it's registering anything. Usually wiring doesn't go bad unless it gets a nick in it or is overloaded and burns out. If it all looks good then check to see if you're getting voltage to the fan motor when turned on. Be sure not to let leads or live wires go to ground or touch you, it can hurt you or your wallet worse. That should be a good start, tell me if it works out.
Oct 18, 2007 | Airtemp B6D30E7A Air Conditioner
Electronics - Others Logo
1,789 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
