Question about Epson Stylus C66 Inkjet Printer
Epsom stylus C66 inkjet printer
When i turn on the printer, the ink and paper buttons flash alternately. When i try to print, the computer shows a message of `printer error'
The last time i used it, it worked fine. Don't know what has happened.
Can you suggest anything?
  • floogal Oct 13, 2008
    i moved my printer when i switched it back on both ink and paper lights were flashing alternately printer error is flashed on screen.the only thing i have done is unplug and plug it back in can anybody help.
  • Sarah32 Nov 22, 2008
    I have the same problem, both lights alternatively flashing when both ink and paper are maintained. It freezes the printer.
    come on someone help us all out!!
This problem is probably caused by a blockage in the ink waste pads. Over time, particularly with increased nozzle cleans the pads get saturated. These can be replaced by an Epson Engineer at a cost of about £30-£40 but probably more effective to buy a new printer. This usually happens when the printer is between 2-5 years old.
Hope this helps
Posted on Nov 26, 2008
White horizontal lines appear on text
Posted on Oct 21, 2008
Ink light and paper light flash alternatively, printer does not work
Hi - According to the Epson manual that error indicates that paper may be blocking movement of the print head.
Turn off the printer, then open the cover and remove any jammed paper or foreign objects. Turn the printer on. If the lights continue to flash you're most likely going to need a dealer service.
Hope it's the paper.
Good Luck, Mikeywaf
Feb 28, 2011 | Epson Stylus C66 Inkjet Printer
I recently replaced an ink cartridge on my Epson stylus C66 and now the ink light and paper light are flashing on and off in turn and I can't get the printer to work. Do you know if there's an easy way to...
yes, this means that the ink waste counter is already in its peak and you need to reset it. try to download the inkpad reset utility through your computer. you will know all of the details from there on once you read them.
it would be
Sep 23, 2009 | Epson Stylus C66 Inkjet Printer
Both the ink and paper feed button are flashing (Epsom c66 printer)
check for a paper jam or an ink cartridge jam which was not properly aligned. usually thse are reasons. also check your ink levels and never touch the part of the ink cartridge connected to the printer. just keep pressing cancel or X, cancel the documents, then load another paper then press on start copy. this should work.
Jul 08, 2009 | Epson Stylus C66 Inkjet Printer
Epson stylus c66 is new but in printing paper comes out blank
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
Red lights flash alternately
Your machine has hit the Ink Overflow Protection Counter Limit. Sounds dreadful but fairly easy to fix.
Get this C66 Rescue Kit and follow the instructions. your printer should spring back to life in no time.
Jul 07, 2008 | Epson Stylus C66 InkJet Photo Printer
Epson c66
Turn the printer off. Open up the cover and check for any obstructions inside the printer. Double check if the ink cartridges are properly plugged in and the tray cover is closed. Turn the printer back on. If you still see the error message, it means that you are having a hardware issue. Then try to contact Epson Technical Support.
United States
Phone Number: (562)276-7525
Hours: Mon.- Fri. 6AM-8PM (PT)
Sat. 7AM-4PM (PT)
Phone Number: (905)709-2567
Hours: Mon.- Fri. 6AM-6PM (PT)
Jan 30, 2008 | Epson Stylus C66 Inkjet Printer
I have a epson stylus c65 printer. My printer is keep flashing the two red light. The out of paper and the out of ink. what do I have to do to stop the problem. The two red light is keep on flashing alternately
Jan 19, 2008 | Epson Stylus Photo R200 InkJet Printer
Epson stylus c66
If your having an error that says "Parts inside the printer are at the end of there Service life" it means that you ink pad is full/ what you can do is change your ink pad and then download an ink pad reset utility so that you can reset the settings/ Make sure to change ink pad before you reset it becuase ink will leak if you don't change it. For the flashing lights, try to check for obstructions inside the printer if not, make sure that ink clicked in and the cover for the tray is closed
Mar 27, 2007 | Epson Stylus C66 Inkjet Printer
Epson Stylus C66 Inkjet Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
