Question about LG Flatron L1750S 17" LCD Monitor
Flickering monitor I have a 17" flat screen LCD monitor. When I switch on the power to my PC, the screen flickers for about a min or two and then gets steady. How to solve this problem? Thanks.
    Problem Solver:
  • 6 Answers
This problem many caused by bad inverter. If invertes not function, it won't feed back a good signal to tell mainboard that LCD backlight is working, so the mainboard turn off the display.
To fix this problem, it is need a qualify technician and inverter's part.
Send it to LG, they will not charge you expensive. LG have a great service.
May this help.
Posted on Oct 10, 2008
Screen making quick flashes
This could be a LCD screen problem or a video card problem.
Connect an external monitor to your laptop, power up the monitor first then boot up your laptop. The video will automatically switch to the external monitor, then go to the Internet and see if this flicker occurs on the external monitor.
If it still flickers then the video card has a problem.
If it does not flicker the the LCD screen maybe faulty.
Get back to me with the results of these test and I can advise the nexr course of action.
Apr 30, 2012 | Acer Aspire One Netbook
My monitor flickers erradically.
Flickering erratically is usually a sign that the fluorescent tubes that light up the LCD are failing, or the high voltage power controller that drives the tubes is failing. Although these can be replaced at some cost and a great deal of expense, it is usually not worth it with very nice, new & larger displays selling for less than $ 150 (23" HD wide screen moitors) from even the best brands such as Samsung, Planar, LG and Viewsonic.
Jan 11, 2011 | Mgc P700 17" Flat Panel LCD Monitor
When I turn my computer on the monitor constantly flickers on and off. After about an hour this stops the the screen goes black about five times, but after that it works fine?
You need to download the latest graphices drivers and get the update for the BIOS.
If the screen flickers in the BIOS screen as well that means the sys has to be repaired for the screen.
Feb 06, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
HP L1720 flickering!
this is common, the display is bad.
all displays, fail. all do. no reason to get angry,
a broken display is worth nearly zero value $0
so how much money will you spend on worthless.?
you can get a new display at Walmart for $65, ,
lines are usually very serious. and is not ever the DC-DC inverter
a bad inverter (< it's power supply) is for the back ground lamps. not data side. the data side is failing and is common, if you twist the screen
it gets worse. ? bingo. data driver connections bad , screen.
IN most cases the part that is bad (screen), costs $100 new. or 50 used
why go there/
Jun 01, 2017 | HP L1720 17 in. Flat Panel LCD Monitor
Philips 17 inch 170s4fg lcd monitor,display flickering
I have Got one philips 170S lcd monitor. Iam having flicker peoblem and my display not stable. pls, give me ur best solution for the above problems.
Jan 10, 2009 | Philips 170S4FG 17" LCD Monitor
Flickering monitor
Flickering screen display
Flickering on the screen can be caused by defective hardware in the computer or by improperly installed software, but it can also be caused by interference from external devices. The following examples describe situations in which your screen could start flickering:
  • Screen starts flickering because of interference caused by devices which generate magnetic fields, for instance:
    • a TV set
    • a laser printer
    • another monitor
    • fluorescent lights
    • hidden power lines
  • Apart from interference, an incorrect setting in your system CMOS setup can also cause flickering. On some systems it is possible to distinguish between interlaced and non-interlaced monitors. The setup of your system should always be colour non-interlaced.
  • Proximity to the monitor of fans, air-conditioning units or other devices with rotating motors.
  • The number of devices using power from the same electrical line. Are you overloading the plug?
  • Monitor placed on an unstable surface.
  • Improper video drivers, this is a software problem, see section B
  • An improperly configured or a defective video card.
Sep 30, 2008 | E-Machines E17T 17" Flat Panel LCD Monitor
Gateway flatscreen monitor
There is a problem with the power supply cable to this monitor. You need to have a new one put on. An easy way to test this is to get it to a shop so they can test the cable.
Jun 11, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Samsubg Monitor flickers
My samsung 740N lcd Monitor is flickering. can i get a solution of this problem?
Jun 10, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
ORANGE FLICKER ON POWER LED
Is the orange flicker on the screen or on the button?
Does it always stay on or does it go off?
What kind of monitor is it? Flat screen LCD or CRT?
Mar 23, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
17" Starlogice Screen
It is the main board power failure in the system due component like capacitors shorted.
Feb 01, 2008 | Star Logic 17" LCD Monitor
LG Flatron L1750S 17" LCD Monitor Logo
436 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
