Question about Apple iPod nano
My ipod is stuck in disk mode
How do i get my ipod out of disk mode
  • Jori10 May 11, 2010
    Nov. 17,2008 My ipod is stuck in disk mode, can some one help me to get out of disk mode.  thank you.
Quick fix - press the menu & center button until the screen lights up or an apple logo appears. Then press the pause button until you can see the menu again.
Posted on Jan 10, 2009
  • 43 Answers
Open itunes
connect your ipod
click on the image of your ipod on the left toolbar labelled "____'s iPod under the heading "devices"
make sure you are in the "summary" tab
under the heading "options" click the box with the sentence "enable disk use" so that the box does not have a tick in it. this should take it out of disk mode. to alternate between to use disk mode, just click the same box.
if this doesnt work, follow the steps called the 5 "Rs" found here
http://www.apple.com/support/ipod/five_rs/
Posted on Oct 24, 2008
EASY SOLUTION
just hold down the menue and center button at the same time untill the apple symbol comes up.
Posted on Feb 07, 2009
  • 31 Answers
This apple ipod troubleshooting blog has explained in details various ipod problem troubleshooting. how to troubleshoot ipod error messages and how to reset and restore ipod from freezing problem.
Posted on Nov 10, 2008
  • 2,071 Answers
If you're having trouble with your iPod, try these steps (known around here as the five Rs) one at a time until the issue is resolved. These steps will often whip your iPod back into shape.
  1. Retry your iPod with a different USB or FireWire port on your computer (please note that the latest iPods can only be synced through USB).
  2. Reset your iPod. To reset an iPod, iPod nano, or iPod mini, press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step. To reset an iPod shuffle, disconnect iPod shuffle from the computer (if connected), and then move the switch on the back of iPod shuffle to the off position. Wait 5 seconds, and then move the switch on the back to the play in order or the shuffle position.
  3. Restart your computer, and make sure that you have the latest software updates installed.
  4. Reinstall your iTunes software and make sure you have downloaded the latest version. Check your iPod software by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and the Version section tells you whether iPod is up to date or needs a newer version of the software. Click Update to install the latest version of the software.
  5. Restore your iPod by connecting your iPod to your computer, and then in iTunes, select your iPod in the Source pane. Click the Summary tab, and click Restore to restore iPod to its original settings. Follow the onscreen instructions to complete the restore process. (Important: Please note that restoring an iPod will erase all songs and files on your iPod and restore it back to its original settings. Make a backup of any files on your iPod before restoring it. After restoring, you can transfer your music and files from your computer back to your iPod again.)
Note: Because Restore erases all of the songs and files on iPod, make sure to back up any files you've saved on the iPod disk. All of your songs, videos, podcasts, audiobooks, and games can be loaded back to your iPod provided that you have them stored in your iTunes Library.
How to restore your iPod:
For Windows:
1. Make sure you've reinstalled the latest version of iTunes.
2. Open iTunes, and then connect your iPod to your computer.
3. After a few moments, it will appear in the source list in iTunes. If the iPod's display doesn't show "Connected" or "Do not disconnect" you may need to put the iPod into disk mode to proceed.
4. Select your iPod in the source list and you will see information about it appear in the Summary tab of the main iTunes windows.
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software.
The 4 possible restore options are:
Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with the latest iPod Software on your computer.
Restore Option 4: Restore and Update - Restores with the latest iPod Software on your computer.
6. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started.
When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
7. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
8. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
For Mac:
5. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download of the latest iPod Software. The 4 possible restore options are:
Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod, even though a newer version is available.
Restore Option 3: Use Newest Version - Restores with latest iPod Software version on your computer.
Restore Option 4: Restore and Update - Restores with latest iPod Software version on your computer.
6. A message will appear prompting you to enter an administrator's name and password.
7. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will instruct you to leave iPod connected to your computer to complete restore.
8. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage.
9. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Or
Try to reinstall
To update and reinstall your iPod software, first download the latest version of iTunes.
http://www.apple.com/itunes/download/
Next, open the new version of iTunes and connect your iPod to your computer.
Select your iPod in the source list and click "Check for Update" under the Summary tab. iTunes will check to see if your iPod needs to be updated and perform the update for you.
Hopes it may help you;
Regards,
VOTIT
Posted on Oct 10, 2008
ctf1800
  • 4402 Answers
SOURCE: Ipod stuck in disk mode
Stuck or frozen
http://ipod.about.com/od/troubleshootingyouripod/ht/reset_ipod_vid.htm
Posted on Dec 19, 2007
SOURCE: ipod is stuck on disk mode.
ahh thanks it works now (:
Posted on Jul 14, 2008
ohms
  • 1879 Answers
ipod instructions here
too many to paste in here
Posted on Sep 02, 2008
SOURCE: iPod Nano A1137 with disk mode message
I have a iPod Mini. I dropped it while in the gym. Now,...
jazzyboy11
  • 728 Answers
SOURCE: stuck ipos in disk mode
Plug it into the computer, and in the ipod's main screen, uncheck the box that says allow disk mode. Hope this works!
Posted on Aug 31, 2009
Its stuck in disk mode screen displays a check mark that says ok to disconnect player wont turn off or go to menu screen
Try resetting it. Hold down the middle and menu buttons at the same time and it should reset itself. Then it should go to the main menu. Good Luck!
Jul 08, 2010 | Apple iPod MA446LL/A MP3 Player
Stuck ipos in disk mode
Aug 31, 2009 | Apple iPod nano 3rd Generation
IPod Nano A1137 with disk mode message
Feb 05, 2009 | Apple iPod nano
Disk Mode
So are you saying it's stuck in disk mode? To get it out of disk mode you have to do a reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
Feb 26, 2008 | Apple iPod nano
Stuck or frozen
Dec 13, 2007 | Apple iPod MA446LL/A MP3 Player
Apple iPod nano Logo
1,584 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
