Question about Philips HTS3450 System
Philips Hts3450 My home theater system (philips Hts 3450) had the same symptoms ('a clicking sound that starts out spaced apart, and progressivly gets closer, and closer, until it becomes one high pitched sound from all my speakers')as what yours did. I have opened the whole thing up and can't find the 470uF/25V capacitors. Can you help me with locating it. My email address is lucaskuhns@gmail.com. Any help would be appreciated.
2 Suggested Answers
SOURCE: Philips HTS 3450 sound
I just blew my subwoofer up. The fuse was blown so I rigged it with something to act as a fuse, and the thing spewd out a volcano of smoke! Oh well..
Posted on Oct 04, 2008
I need to connect a subwoffer VGA with an stereo receiver. Do you know where I can find a cable to do this?
i have hts 3455/98 i connect perfectly all cables but sound is coming from only one speaker. pl help me about this problem.
Mar 28, 2013 | Philips HTS3450 System
Why won't my TV sound go through the Hts 3450?
Wide open one here. Is your tv coming in direct from the wall or do you have a cable/digital box that you need to get the signal from? If you have a box then make sure you are plugged into the audio out on the box and on the HTS you are on the audio in. There will be a left and right. If you have the sound to your tv then you can plug into the audio out on your tv and again plug into your audio in on your box. If your tv has an option for external speakers then you need to make that adjustment on the audio menu on your tv. Also make sure that the proper channel is selected on your HTS and that your audio output matches your selection. Hope this helps but I will keep an eye out for further posts.
Nov 12, 2012 | Philips HTS3450 System
I have a philips hts 3450 i just bought and i didnt get the speakers is there a way of hooking it to my tv and get it to work
Speakers are an integral part of any home thetre system and are, as such, effictively useless without them. You will need to attach some speakers to it in order for it to work as intended.
Jan 23, 2011 | Philips HTS3450 System
When turn the system on freezes on "disc" then nothing works
Replace the dvd player with a HTS 3450 dvd player from ebay. Average price is $20-$30.
Feb 05, 2010 | Philips HTS3450 System
Need region free code for philips hts 3450
Turn it on. Do the following (with the remote).
  1. Press "Open/Close"
  2. Press 9 9 9 9 0
  3. Press "Open/Close"
It should say "Region: 0" in the upper left corner.
Jan 22, 2009 | Philips HTS3450 System
Fuse keeps blowing in the subwoofer on my Philips hts-3450
Replace the capacitors with ones of the correct v. Download latest manual from Philips website to verify if the capacity value is not a typing error.
Jan 03, 2009 | Philips HTS3450 System
Hts 3450 home theatre system- dvd in player- but won't come out
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be taken apart to remove the disk.
Dec 10, 2008 | Philips HTS3450 System
Sep 21, 2008 | Philips HTS3450 System
HTS 3450 subwoffer off
I have a similar problem. I inspected the power board and found IC901 burned completely. I cannot find out the part number and have tried to get a reply from phillips but have not heard back from them. Anyone have a schematic or can give me the part # of IC901?
Sep 06, 2008 | Philips HTS3450 System
Buzzing noise
If the sound goes out completely, try hitting the mute button (to mute it) and then hit it again (to un-mute). I've found that this work-around typically gets it working, at least.
Jan 03, 2008 | Philips HTS3450 System
Philips HTS3450 System Logo
93 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
