Question about Microwave Ovens
Ge microwave model # JE2160SF03
This microwave emitted a bad smell and stopped working. It will still countdown, turntable, beep, etc but no longer heats food. It was manufactured in 2006 so I wonder if it is still under warranty.
  • 99 Answers
Sounds like rectifier gone.Needs testing by microwave engineer
Posted on Oct 11, 2008
My microwave has stopped working. Everything functions properly, including the light when the door is open, and the timer countdown begins when I press start, but the actual unit will not turn on...
Sounds like a bad magnatron (the part that emits microwave energy) or maybe just a bad door switch. If the door switch is bad it won't let the unit come on.
Feb 19, 2015 | In Microwave Ovens
Why does my ge spacemaker jvm1740dd1cc no longer heats and the turntable does not work?
Bad door switch. Look for burnt terminals on one of the door switches. Replace the switch and cut off the burnt terminals and splice on new ones.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
GE profile JE2160SF03 microwave oven doesn't heat
3 things high heat low heat cencor or magnatron is bad
Apr 02, 2013 | Microwave Ovens
Microwave making noise all the time if plugged in & door shut
Sounds like a bad control board. Change it or buy another unit.
Jan 21, 2013 | DeLonghi Microwave Ovens
My Micro will not heat and it keeps beeping I can not get it to stop...
Its likely beeping as it is not heating, I presume light goes out when door closed and a turntable turns or not?
I can provide possible reasons for no heating etc.
Dec 21, 2012 | GE JES1142SF Microwave Oven
Ge microwave je2160sf03
From the description one of the door switches is defective, or a more serious problem has developed.
Jun 02, 2012 | GE Spacemaker Over-the-Range Microwave
Countdown through oven's Power Levels
Check that particular outlet for a neutral ground
May 29, 2009 | Panasonic Microwave Ovens
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
Ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Aug 02, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Microwave JVM165OWB005--No more heat!
If you look at consumer affairs.com, there are many problems like this with GE microwaves. Not a good track record, experiencing problems with mine as well.
Apr 15, 2008 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
684 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
