Question about HP OfficeJet 7310 All-In-One InkJet Printer
Paper jam paper got JAMED and tried to remove it and now paper is stuck inside somewhere. how can i get the paper left in the printer out. i can not see any paper but know it is inside. i have a HP PSC 700 Series All-in-One printer. thank you
  • 34 Answers
There is usually a door on the back or side of the printer that you can open. Or a button that will open a door. Look in these if you find them. You might be able to find the paper.
Posted on Oct 09, 2008
Paper jam 2, check inside
You should troubleshoot jamming error message by removing toner cartrige, check if the little plastic sensors on the paper path are not stuck somehow, reinsert toner,close door, open back door check if the fuser sensor is ok ( and not broken), clean the papertray roller, restart printer and it should work. If that doesnt fix your problem it can be a faulty sensor or some tiny paper left somewhere you can't see and sensor detects .. Hope it helps.
Apr 07, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Says paper jammed i pulled out still says paper jamed
When you removed the paper did it tear or it came out in one piece.
If not there will be a small piece of paper left inside and this needs to be removed.
Apr 15, 2012 | Canon Office Equipment & Supplies
Jamed paperc86 paper is jamed
Epson Stylus InkJet Clear a paper jam in printer
Jan 05, 2012 | Epson Stylus C86 InkJet Printer
Samsung CLX3170 printer makes loud clanging noise when printing and smudges some lines. Started after a paper jam. Have turned off/on several times
there is a rest of the paper jamed still inside the printer you need to remove all the jamed paper then it will work, to find out where the paper stuck's open the front and rear cover, maby you have to remove the toner cardriges as well.
May 17, 2011 | Samsung CLX-3175FN Color Laser All-in-One...
I have an envelope stuck inside my canon mp620 printer somewhere. How do i get it out?
There are three areas for paper jam clearing.
1. Under the scanner cover
2. At the rear of the printer is a small door with rollers at the top. it comes away from the printer from the left. There are some small pins to hold it in on the right. Swing it out to remove the door.
3. The cassette tray. Remove the tray to expose jammed paper or envelopes.
Here is the diagram for the rear door.
Do not touch any components inside the printer.
May 21, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Stylus CX9400 Photo Printer: paper jammed inside printer...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
May 18, 2010 | Epson Stylus CX9400 Photo Printer
My epson cx3200 says paper jam, I dont see any paper jamed, when i press the button to say ive cleared it,it then runs a sheet of paper through it and says paper jam again, surely if there was a paper jam...
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Dec 06, 2009 | HP PSC 2210 All-In-One InkJet Printer
After paper jamming in printer paper now wrinkles
there still may be a piece stuck somewhere in the unit. Remove printer cover and check inside to see if there is anything at all still in there
Jul 29, 2009 | HP Officejet 5610 All-In-One InkJet...
Error Light on Brother HL-2170W
Do not try to depress the green lever, since you need to remove the cartridge AND its base altogether. Just grab the front middle part of the assembly, pull it out slowly and steadily. You may need to apply extra force in doing so as it does take some effort to disengage the cartridge assemly from its seated position.
After the cartridge is removed, you may find some jamed paper inside. simply remove it and the printer should work again.
You may email me at stevenjoy@gmail.com should you have further questions.
May 12, 2009 | Brother HL-2040 Laser Printer
Clear paper jam
Sometimes there is little bits of paper stuck inside a sensor causing the printer to detect a jam. Use an air duster can to and shoot some air at all the sensors. The sensors look like little plastic fingers that get pushed down when paper moves over them.
Jan 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
