Question about Microsoft Office Professional 2007 Full Version for PC
Word 2007 My computer had a faulty motherboard and started crashing all the time and then rebooting. The motherboard was replaced today. However, now I cannot access my Word file and folders, even though they are still showing up in Word. I keep getting a message that says, "This file is not available." I can open pictures and other items in Word, just not documents that I created in Word. Also, I cannot access any new documents that I create and save in Word. I tried reinstalling my Microsoft Office Home and Student 2007 but that didn't help.
    Sniper:
  • 55 Answers
Are u sure that u created ur doc in office 2007 only and u r opening it in office 2007 only
if, why dont u try office 2007 standard, here is the key for Microsoft Office Standard 2007 :
CTKXX-M97FT-89PW2-DHKD3-74MYJ
try this it might help u.
dont try to repair ur Windows Xp it wont help u in this situation, infact it wud take lot of time and even wont repair it
Might b that it can also b a problem with the extesion of file
MS office 2007 has .docx extension
whereas MS office 2003 has .doc
Posted on Oct 10, 2008
    Scholar:
  • 105 Answers
What operating system are you using?
Try starting the repair wizard from the installation CD.
Toshiba satellite L355-S7812 keeps crashing
One bad lead or faulty connection point can cause a computer to shutdown continue restarting on a cycle or fail to detect your hard drive boot up
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure it has charge and they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 30, 2012 | Lifetime Toshiba Satellite L355-S7812...
Tip
My Computer will NOT start up blank screen?
So, your computer wont start up? What to do? First disconnect all attached devices, Then we must check to see if there is any Power, Try unit in another power point, if Power Point proved OK, then try & change the Power Lead in, proved OK, then Check the Power Supply, do you see the Fan "Kick"? On the Power Supply AND the CPU Fan inside, proved OK, then Check to see if there is power to the Motherboard? Often there are LED's that show if power is ON. proved OK? We must now remove the Power from each device, DVD, Hard Drive, leaving ONLY the MotherBoard connected. OK, So we are at the MotherBoard, it still won't power up, everything else has been removed... now remove the RAM. power up, Proved OK, if NOT, then the RAM is your problem replace.it power ON, Proved OK, If not then your MotherBoard is Faulty, proved OK, then start attaching devices and re-starting & rebooting each time until you find the one that stops the PSU. That is your problem. At each step if you don't have a, proved OK, then, that last step was your faulty bit, replace or remove.
What we have to do is at each juncture we must test each item in turn, and do a reboot each time connecting & disconnecting to prove the faulty bit.
So say we have tested all from Power Socket to MotherBoard & RAM all test OK, then we start to attach the hard drive & it won't power up, or say it was the DVD, This then is the source of your problems.
on Jan 30, 2010 | Computers & Internet
Pc reboots at "starting windows"
im not sure what this isn't you are refering to i come from the old school of english
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error hope this helps
Apr 17, 2011 | Foxconn M61PMV Motherboard
My computer started crashing and I could not use reset or switch on front of computer. I had to disconnect the power. wait 10 seconds then turn on power and restart. when computer crashed the fans were...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
or it might be your graphics card make sure its securely seated and there is no dust built up
on and around the graphics card hope this helps
Mar 25, 2011 | Mercury P4VM800M7 Motherboard
Fequent crashes.Slow booting up .
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer also select users you will see who is using your computer then you might
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your hard drive the ones from your motherboard
Test the leads that attach to your ((hard drive from the motherboard)) or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your ((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Jan 07, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
When did the system rebooted and started the boot sequence, the screen showed only one line and froze. Then I took my flash drive and rebooted again. then again it does not start, black screen and no...
Test the leads that attach to your hard drive from the motherboard or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
hope this helps
Dec 21, 2010 | Foxconn K8M890M2MB-RS2H AM2 VIA K8M890...
On starting the color of monitor screen got parallel lines and colors screen becaim faint due to this computer became hanged. Some times it works properly for some minutes but laterly the same fault...
Video corruption - the video chip is faulty . Because the video chip is part of the chipset it means that the chipset is faulty, which causes the pc to crash.
Sorry, the motherboard is dying, you will have to replace it.
Nov 24, 2010 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
Frequent hard disk failure
check your hard disk cable first and replace it.if this isn' stopin your problem then make a new bios flash. may be ypur bios is reporting your hdd wrong so make a new one. if even after this you can not stoping your problem bay another mb.
Apr 05, 2009 | Intel D945GNT Motherboard
Crash when re-connected to power supply
Go into msconfig and disable all your programs then let the notebook reboot. After it reboots and goes back into windows. Try to unplug it and plug it back in and see if it does the same thing, if so then you might need to wipe out the drive and start over fresh. If it doesn't crash on you after disable the programs and unplug and replug then you have some software that isn't interfering with the power options that controls windows.
Aug 13, 2008 | Acer Aspire 5002WLMi Notebook
Restarte again and agian
check your cmos CR2032 battery on the motherboard as this can cause restarts because of bios settings,when booting press F2 or Del and check the date and time to see if incorrect. Also it maybe a faulty driver causing the crash, you can tell the bios to halt on all errors instead of rebooting, this can be found in the main cmos settings menu normally below the list of drives and check to see if halt on all errors is enabled, this way you can try to see what is causing the reboots.
Jun 24, 2007 | NEC Galileo 845GL (N4-IBFGL) Motherboard
Microsoft Office Professional 2007 Full Version for PC Logo
106 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
