Ive had to buy a replacement choke lever as a car ran over my bike and broke it.it snapped the choke lever off just leaving its base plate on,how do i fit the new leaver on.thanks
SOURCE: Yamaha XT 125 Clutch Problem
change the clutch basket and buy a new cable they get stretched out and the basket gets worn severly
SOURCE: 03 yamaha tw 125cc, bike wont go
Could be a number of things....but sounds like it might be fuel starvation. Check your fuel filter and maybe replace it. Check and make sure there is fuel flowing to the carb. After that you would have to service the carb.
SOURCE: how to change oil
simply remove the sump plug which is in the form of a bolt in the bottom of the engine you may need to remove sump guard if you bike has one fitted once drained you may want to flush it with a good quality engine flush then just refill with the correct amount which is usually stated on the clutch casing near the filler cap hope thos helps
SOURCE: yamaha xt 125 battery problem
My yam xt 125 only goes 50mph and should have a top speed of 70mph what could cause this ?
SOURCE: how to cleane in bike air filter yamaha gladiator
hi sandeep;
http://www.youtube.com/watch?v=QR6pGeF-Zw4
pls go through the vedio
