Question about Kenmore Oasis HE 27082 Top Load Washer
Loud Sound During the Spin Cycle it starts thudding very loud as if someone is pounding on it. What's wrong with it?
  • 750 Answers
Bash11385,
Welcome,
You said, during the Spin Cycle it starts thudding very loud as if someone is pounding on it. What's wrong with it?
You must check tht the wheels are properly installed and lock nuts are tight.
Your washer load is more than likely out of balance or over loaded .
Try moving the clothes around so the weight is balanced .
And remember not to over load the washer with to many articles!
let me know how it goes.
Huuum Please remember to leave a rating.
Below is the Kenmore site for your washer manual if you do not have one!
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0512076.pdf
Posted on Oct 10, 2008
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
Aug 07, 2015 | Kenmore 24032\24036 Top Load Washer
Loud noise during spin cycle now they are stacked
a loud noise comes when you forget to remove shipping bolts after installation or if the shocks are worn out it makes noise thirdly the bearings might be worn out if the washer is more than 6years old
Jan 21, 2013 | LG Cherry Red Steamwasher Wm2487h Front...
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Washing machine making loud roaring sound during spin cycle
Very likely the main bearing and drum shaft-inner tub will need replace. Not worth repairing, easily can cost more than the washer. Buy a new whirlpool front load duet, super capacity or the top load whirlpool with and agitator. Good Luck, Appliance Specialists
Feb 16, 2010 | Washing Machines
During the spin cycle the machine made a loud thud and now during spin cycles the machine pounds and slams yet when the machine is off the basket spins freely and without obstruction... any suggestions?...
It is doutful the basket or drum has warped. With such a loud thud and still doing it when you use the machine, it appears one of the balance springs or its mounting has broken loose. This will require opening the shell of the machine. Some models have a 3 point suspension, others have a 4 point suspension. This broken suspension point will account for the fact that you can spin the drum feely by hand yet it goes crazy when spinning with a load.
Because it is a front load unit, you must be careful or have a certain level of knowledge to open the unit and reclose it with the drum, seal, and facing all lining-up and not binding. As always, unplug the unit before taking it apart. Good Luck. Macgivor
Sep 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Apr 05, 2009 | GE WJSR2070B Top Load Washer
is it more like a roar or a train going by? if so your rear tub bearing is going out. very expensive have to replace the tub, basket, spinner ring and shaft and seals about 4 hrs for an exprienced tech to do took me 7 hrs to do for the first time. but it will be very close to $1000 to have done not much less to do it yourself.
Mar 09, 2009 | Washing Machines
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
150 people viewed this question
Sal De
fordexpert
Robert Rankin
