We are after xerox cartridge ct350269 - Office Equipment & Supplies
  • 34 Answers
This?
http://www.printzone.com.au/product_info.php?products_id=3439
Posted on Oct 09, 2008
CRUM ID 093-926
That error signifies an unsupported black toner cartridge. Verify oem Xerox cartridge, try reseat cartridge. If not cartridge it will be the MCU Board, part number 960K60951.
http://www.iteminconline.com/960k60951_062k23373-960k60951-xerox-workcentre-wc6015-engine-controller-mcu.htm
Jan 31, 2016 | Xerox 6015/NI New Workcenter 6015/NI Laser...
Printer Error: 93,984.00:34602 Xerox colorqube 8570
Check the crum for the cartridge. And does it fix proborly
Oct 22, 2015 | Xerox Office Equipment & Supplies
Xerox is printing pages with a red line down the left side
Streak in only one color:
Check the condition of the print cartridge, and replace as necessary.
Verify that the print cartridges (C/M/Y/K) are genuine Xerox cartridges,
and replace if necessary.
http://download.support.xerox.com/pub/docs/6180MFP/userdocs/any-os/en/user_guide_en.pdf
May 05, 2014 | Xerox 6180MFP/D Printer
Error 061-391 xerox
I would suggest replacing the Yellow cartridge with an OEM cartridge and testing again. Also, check the contacts between the cartridge and the printer top make sure they are clean and not bent.
An OEM cartridge is an original Xerox cartridge. There are also third-party compatible cartridges and remanufactured cartridges. I wanted to make sure that the replacement is a Xerox brand new cartridge. The other possibility as I said, is that the sensors are not making proper contact with the cartridge. Make sure the contacts are clean and that none of them are bent.
if this doesn't help then there is something wrong internally with one of the PCBs and it will require service.
Mar 03, 2014 | Xerox WorkCentre 7132 Multifunction Color...
Replace drum in xerox phaser
asic technical parameters forToner cartridge chip of Xerox Phaser 3450B:
chip-b.jpg" ]
Version: No area limited
Yield: 5,000-10,000.
Printers Model compatible: Xerox Phaser 3450B
Toner cartridge Model: Xerox 106R00687-BK and Xerox 106R00688-BK.
Manufacturer regulations pages yield ofToner cartridge chip for Xerox Phaser 3450Bis 5,000-10,000 then printer do not print andDrum chip for Xerox Phaser 3450Bhas mission paper pages count.You should resetDrum chip for Xerox Phaser 3450Bcaused by following reasons:
And then, you can choose one in three following plans: replace Toner cartridge, replace Drum chip or reset Toner cartridge chip.
1.Replace new Toner cartridge for Xerox Phaser 3450B:
- If you choose plan replace Toner cartridge then cost is too high. Each Toner cartridge for Xerox Phaser 3450B (Xerox 106R00687-BK and Xerox 106R00688-BK Toner cartridge) costs about $150 - $200
- With replace new Toner cartridge solution is not optimal, because the price is quite expensive.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new unit.
2.Replace new Toner cartridge chip for Xerox Phaser 3450B :
khe-chip-b.jpg" ]
- If you choose plan replace Drum chip then cost higher than reset chip. EachToner cartridge chip for Xerox Phaser 3450Bcosts about $6 - $10/color.
- With replace new Toner cartridge chip solution is cheaper replace new Toner cartridge.
- When Xerox Phaser 3450B shows errors about computing limits of Toner cartridge chip, you continue to replace new Toner cartridge chip.
3. Reset Toner cartridge chip for Xerox Phaser 3450B
If you choose plan resetToner cartridge chip for Xerox Phaser 3450Bthen that is best plan. It cheaper than replace Toner cartridge or replace Drum chip
The phenomenonToner cartridge chip for Xerox Phaser 3450Bout of count are printer do not print and display error on the LCD monitor:
-"Drum low", "Drum eppty", on monitor laptop or desktop appear yellow exclamation mark corresponding color, on monitor printer report Drum empty.
-"Tone life end", "Replace new unit"
- "The x unit an error". In that "x" is color of Toner cartridge or code of Toner cartridge
How to fix the errors:"Drum low", "Drum eppty", on monitor appear yellow exclamation mark corresponding color,"Tone life end", "Replace new unit", "The x unit an error"? cheaper, the most effective.
We use unismart device toreset Drum chip for Xerox Phaser 3450B
Unismart is a device reset Drum chip. Unismart can reset for many Drum chip of manufacturers: Samsung, Hp, Canon, Epson, OKI, Xerox ...
Unismart system is designed to offer a complete solution for writing, resetting, testing various chips with the combination of Unismart Box and Unismart chips. Unismart include: unismart box and test head, power adapter, Data wire, flat writer.
unismart1.jpg" ]
Test head is used for data transmission between Unismart Box and Unismart chips. There are 20 types of test heads designed according to different chip shape, which can be used for operation on all chip models that
current Unismart system supports. Please choose the right test head in accordance with the PCB code. Some PCBs share a same test head, which is clearly indicated in the chip compatible list.
In Case You Still Having Problem Then Follow Us For On :Xerox Printer Support
Jan 23, 2014 | Xerox Phaser® 860, 8200 Standard Capacity...
How to refill fuji xerox docuprint p205b toner cartridge
Need to know how to refill the cartridge for xerox p205b , please email to me : myprinterwork@gmail.com . toner and chip also i got
Sep 05, 2012 | Fuji Office Equipment & Supplies
Stuck toner xerox phaser 6140
I am sorry I can not help you. I am having the same problem with a magenta cartridge (also non Xerox)I tried disassembling but I could not find my way. For the time being I am printing B&W .
the other replies are not very relevant I am afraid.
Feb 16, 2012 | Xerox Phaser 6140v_n Blk18/colour20 Pp -...
Need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
need solutons for xerox phaser 3100 after refill message toner empty. how to reset and usr this cartridge
Aug 08, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Cartridge
When either printing or xerox is faint or leaving pages blank in between then your cartridge is almost empty. Get it refilled.
Jun 18, 2008 | Xerox WorkCentre PE16 All-In-One Laser...
jasbo
jasbo
