Question about Dell Inspiron 1300 Notebook
Inspiron 1300 - will not completely come up
After turning on the power button. A black screen with white lettering comes up stating:
We apologize for the inconvenience, but windows did not start successfully. A recent hardware or software change might have caused this.
If your computer stopped responding, et..... choose Last known good configuration to revert to the most recent settings that worked.
If a previous startup attempt was interrupted due to a power failure or because the power or reset button was pressed, or if you arent't sure what caused the problem, choose start windows normally.
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
I don't know what caused this problem. It was last used about 10:00 a.m. today and when trying to turn it on later today, this came up.
I have tried all modes and nothing works.
  • Anonymous Oct 11, 2008
    Have same problem--will not boot up in any od the possible configs. Tried each one and no go. Tried the "kill" also. Nothhing helped.
    Problem Solver:
  • 35 Answers
Try to boot it to last known configuration.
Hope it will work.
Posted on Oct 09, 2008
Dell inspiron N7010 wot't turn on.
call tech support and get a complete diagnostics done.
Feb 19, 2014 | Dell Inspiron N7010-JQ02DN1 17R Laptop PC...
Dell inspirion 1300 screen goes black
Turn OFF the laptop, unplug the ac adapter and remove the battery.
Without the battery and ac adapter, hold the power button for 10 secs.
Put the power sources back and turn ON.
Mar 01, 2011 | Dell Inspiron 1300 Notebook
Hello I have got suddenly a white screen after starting the 5 year old Dell inspiron 1300. In the background the typicall sound of the Windows XP startprocedure can be heard, but I dont get any readable...
Hi holm_fischer,
White screen often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
1. Turn off the computer.
2. Unplug the AC adapter from the power outlet and take out the battery from the system.
3. Now, press the power button for about 15-20 seconds.
4. Put back the battery in and plug the AC adapter.
5. Turn on the system and try observing it.
--> If power drain did not work, you need to consult a repairman to have your screen be checked for possible damage.
Hope it helps.
Thank you for using FixYa.
Nov 28, 2010 | Dell Inspiron 1300 Notebook
Hi. I have an Inspiron 1300. Suddenly, the screen ...
Black screen is often caused by a defective screen. The easiest way to determine if you have a hardware or software problem is by performing a power drain. Please follow the steps below for additional instructions.
Power Drain:
Hope it helps.
May 21, 2010 | Dell Inspiron 1300 Notebook
Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
Oct 01, 2009 | Dell Inspiron 1300 Notebook
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Someone changed my password and now i dont know it
Ok its kinda tricky but this should work fine but you have to follow these steps...
Turn the laptop on..as soon as you hit the power button start hitting the f8 button repeatedly until the screen comes up with a black backround and white lettering. Use the arrow keys to highlight and select 'Safe Mode' hit enter. When it boots into windows it will give you the option to choose the admistrator as the sign on. Choose the admin and let the computer boot up. (the screen, icons, and lettering will be large) When its up and running choose start then control panel then user accounts. Choose manage other accounts and select the one you want to remove the password from. Then select remove password from one of the options. Once that is done reboot and no more password.
Hope that is easy to follow
May 19, 2009 | Dell Inspiron E1505 Notebook
I have a bell inspiron 1300 and when i type my
Sounds like a Malware issue. I would suggest attempting to boot into Safe Mode.
Continously pressing F8 while the machine is booting from a completely powered down state will get you to a Boot Option menu.
Also, Are other profiles effected? Try them in safe-mode as well.
Apr 13, 2009 | Dell Inspiron 1300 Notebook
Button sequence for head test (to look for banding)
Turn the printer off.
Load a sheet of white laser paper.
Press and hold the "Power" & "Ready/FF" buttons at the same time.
Release the "Power" button, and keep pressing the Ready/FF" button.
Right after you release the "Power" button, count 4 seconds, and release the Ready/FF" button.
Immediately, press and release the "Ready/FF" button one last time.
The printer should start printing a series of letters, numbers, horizontal lines and a black solid bar at the bottom of the sheet.
Once this test page is completed, turn the printer off to stop the test.
Feb 06, 2009 | Alps MD 1300 Thermal Printer
Dell Inspiron 1300 Notebook Logo
275 people viewed this question
Alun Cox
