Question about Sony STR-DE635 Receiver
Bought some replacement speakers and the reciever seems to get ver hot!
I've had this receiver for about 7 years, still works fine. However it was purchase as a component system and a few of the speakers crapped out. So I purchased a set of sony 5 1/4 side speakers and a sony 70w rms 100w amped sub as replacements. All seems to be working well and sounds great but the receiver gets a little hotter then it use too, not hot enough to burn your hand but close. Is this something I should worry about?
  • wonderous48 Oct 10, 2008
    Well the speakers are 8ohm, and the receiver is set for 8 but has a switch so you can go either 4 or 8ohm. As far as the sub wire, I used the same wiring as I had used for the original sub. I did notice the wire that came with the sub being a bit thinner but it was not long enough to reach the intended location of the sub. I believe I am using the audio out. The receiver has two sub connections and the old sub use to plug into both but the new one only uses the one which I have connected to the audio out. Could it be that maybe the speakers are just pulling a little too much power?
    Scholar:
  • 142 Answers
Hello! Yes, you need to worry when a Sony gets hot!! You probably have replaced factory 8 ohm speakers with 4 ohm speakers. Look on the back of your new speakers and see what they are. Then look at the rear of your receiver by the speaker terminals and there will be a sentence like "8 Ohm minimum per channel". If your Sony says " 8 ohms " you need to use 8 ohm speakers.
Also, are you a using low level signal ( audio out ) to drive your sub or are you using high level ( speaker line )??? I'd use low level. Good luck!!
barneyluc
Posted on Oct 10, 2008
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
My left rear speaker has no sound. All others work. I have tested the speaker on a different reciever and it works fine. My reciever is a integra DTR 5.5
Swap your left and right rear speaker over. If you still get no sound from the right speaker connected to the left speaker connection on the receiver, then you have a fault on the receiver output. Check your manual first to see if any setting switch off the rear speaker before taking the unit for repair or replace
Nov 26, 2009 | Integra Audio Players & Recorders
Receiver taking a long time to transmit reciever
I assume that the HDMI works fine if you go directly from the dish receiver to the TV with either HDMI cable. And try it with a different source (DVD or x-box) in the same input port.
Take it to a Radio Shack there service centers can repair Onkyo in warranty. Most Onkyo receivers carry a two year warranty.
Nov 18, 2009 | Audio Players & Recorders
Sony str de405 receiver...was working fine, now no sound
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
May 14, 2009 | Sony STR-DE405
Onkyo TX-SR702 keeps going into speaker setup mode
Los amplificadores de audio del aparato estan a punto de danarse,checa las bocinas una por una a ver si no hay alguna mala.
Apr 14, 2008 | Onkyo TX-SR602 Receiver
Hook up problems
either cut an rca cable and splice it to the speaker wires (not easy because the rca cable is coax type or buy rca ends from radio shack and do a little soldering
Jan 02, 2008 | Sony STR-DE835 Receiver
Cerwin Vega ve-28s subwoofer and new Cervin Vega 2-way satellites
I bought my VE-28s and it did exactly that crackled, cerwin replaced part in amp but few months later problem persisted. they then replaced entire amp assembly and its been fine. i really push it to and its been fine. to test it, unplug the connection from amp/ reciever and see if it persists. if so its the sub, if not its the amp/ reciever. dont dump it, these subs really crank and can put out some deep loud bass.
Oct 28, 2007 | Cerwin Vega VE-28S Subwoofer
No Sound when I play DVD's
The optical connection on the TV is most likely an input, not an output. You need to connect the Xbox to the receiver, then the TV. If the receiver does not have a HDMI input, use another audio or digital out from the Xbox to the receiver.
Sep 19, 2007 | Yamaha HTR-5940 Receiver
No surround sound with dolby
I have the same system, the ports for surround speakers only seem to work with the actual surround speakers I bought mine with. I did try to change them but found a sound issue. Looking to buy a new 5 cd changer as mine was damaged during our recent move. Looking to buy model number DX-Z9400M
May 19, 2007 | Aiwa AV-D57 Receiver
151 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
