Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi WD62526 - Error/repair code
Trovlo- my code is 36. I've tried to find out what that code is..but no luck. Back in April it went out..repair service was called..I finally got it fixed in early June. They replaced the lamp 4 times, optical engine 2 times, had the PCB formatted, fmt board ,and the ballast replaced. It has gone out on my again..2 months later!!!
  • 80 Answers
Error Code Probable Cause
12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
remove the back and lamp (make sure the lamp door is on) turn the tv on and look to see if the fan is running (keep you hand out of the tv when doing this - as the lamp connectors are empty) if the fan does not start - replace lamp - the connector is located under lamp housing connector JA - measure the red wire and ground (any metal part) for 12v at turn on - if 12v replace fan - if no 12v check the power pcb
Posted on Oct 16, 2008
C3200 stuck on error screen
did you check the contact from unit 1 and at the back or a connector rest error,power supply board
Feb 18, 2013 | Canon imageRUNNER C3200 Copier
How do i find the dm board for mitsubishi wd62526
If you cannot find it I doubt you will be able to replace the parts but I seem to recall seeing a video or two on U Tube about this.
Jun 16, 2012 | Mitsubishi WD-62526 Projection TV
I have a 2005 Mitsubishi WD62327 62" rear
Yes, this kind of symptoms is not costly to repair. I can assist you which part gone bad on this error code. Click here.
Jdvillanueva
Oct 03, 2011 | Mitsubishi Televison & Video
I have a error code 33, what error code is 33
Hi, These are some codes to your DLP HDTV.
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Jul 20, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Error code 36 when transferring photos to harddrive
According to Microsoft, error 36 is:
"ERROR_SHARING_BUFFER_EXCEEDED
36 (0x24) - Too many files opened for sharing."
There may be many causes for this. Do a virus scan and run the registry repair tool from this download link:
http://www.windows-error-repair.org/tools/regcuredownload.php
Run the tool, press the scan button and let the tool clean and fix your registry.
Good Luck!
Apr 05, 2010 | LaCie Computers & Internet
Mitsubishi tv error code 21
The service manual does not list an error code for "21".
Here are the error codes:
32 Lamp Cover open
34 Lamp abnormality
41 Short Detected
Sep 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
New codes !! april
my box went off i tried these codes on telewest and all off my channels came back on , good luck and pass it on if it helps .
Apr 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
My T.V.
Do self diagnosis test by pressing input and menu on set at the same time for 5 sec. It should blink a 2 digit code. Remember code and let me know.
Dec 03, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
626 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
