Question about RCA D52W19 52" Rear Projection Television
Tosiba 52" dlp won't stay on? - RCA D52W19 52" Rear Projection Television
  • jimnecci2 May 11, 2010
    I have an RCA TV model D52W14YX1. The power button will not stay lit and the tv will not function.
    The light blinks three times then goes out altogether. If I wait for one minute I can try turning the set on again.
  • RCA Master
  • 5,138 Answers
Bad Lamp.
Posted on Dec 21, 2008
My "50" RCA Scenium won't
That's usually caused by a bad lamp. However that chassis is famous for having bad caps on the power board. The repair kit is available at the following link and has repair instructions included.
Aug 16, 2011 | RCA HDLP50W151 50" Rear Projection HDTV
How heavy is a hitachi 52 inch dlp tv
The weight of the hitachi 52 inch TV is around 94.1 lbs 0r 42.6 Kg
Jul 31, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
I turn on my tv then it immediately shuts back off and now i cant get it to stay on. Why is that?
I think you have a dlp tv . always first unplug from wall 10 to 20 minutes to reset micro pross. if that don't work mit dlp tvs are known to have bad filtor capacitors. and always make shure you have good lamp. J.D.W.
Jun 24, 2010 | Mitsubishi WD-52525 52" Rear Projection...
My Toshiba 52" goes dark. what can I do to fix it.Tried to ajust the brightness but still stays dark.
U replaced the bulb yet on this tv?U used this tv alot at lest two years or more?The bulb life span it over,bulb have limitted life span.
Apr 20, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Our TV is making a loud humming noise. We think
It's likely your color wheel rather then your fan. I've replaced quite a few of these and the fans are usually good. Get and estimate - I generally charge $250-350 Total
also google your model # and color wheel to investigate further.
Oct 24, 2009 | Toshiba 52HM95 52" HDTV Projection...
TOSHIBA dlp projection, model 42hm66 won't stay on
Could be the power supply. You can check the power from supply with multi-tester or voltmeter. If have a service manual, then I suggest testing the ballast as well
Aug 07, 2009 | Toshiba 52HM95 52" HDTV Projection...
Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Apr 18, 2009 | Mitsubishi WD-52525 52" Rear Projection...
What do i use to clean the screen on my 52 inch tosiba regza LCD tv
A slight damp cotton cloth, do not use any chemicals on the screen because it will marr the finish and cause you to have a bad image
Aug 15, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
