Question about IBM 11P836402 for ThinkPad R40 Monitor
Monitor My husbands computer will turn on, monitor light is blue showing it is on but the screen will only show for a second then it fades out. It is as if a bulb has burned out. Is there a led in the monitor or what do you think this could be? Thanks
    Genius:
  • 1,124 Answers
Try connecting another monitor first, but seem to be related to your video card.
Check the video card on your computer.
Posted on Oct 09, 2008
  • Pablo Csaky
    Pablo Csaky Oct 17, 2008
    Thank you for using FIXYA!
    Dont forget to rate my help!
    Have a great day!
    Pablo :-)
    Let me know if you have further questions about this issue.
Power blue light flashing when i turn the computer on
It depends on where the blue light is. Is the blue light on the monitor or on the computer tower? If it is on the monitor the monitor is having problems and needs to be serviced. If it is on the tower it could be an issue with the power supply.
Jan 17, 2013 | Gateway DX4720-03 PC Desktop
I have a gateway FPD1975W monitor with a Gateway GT5482E computer. The monitor does not display the computer output - the blue power light blinks off and on steadily and every so often the monitor says...
From your description you have a power supply problem, usually caused by defective capacitors, sometimes they will bulge at the top indicating an open condition. If you decide to repair check the inverter board that powers the back lights behind the screen, because they are also prone to bad caps.
Feb 17, 2011 | Gateway FPD1975 19" LCD Monitor
When my computer boots up sometimes the screen is ok, but more often the screen fades and goes black. If I switch the monitor off and then on again the screen shows the icons etc for about 2 seconds and...
This could be that the screen topback light or bottom back light is bad or the inverter.
the topback or bottom back light could also be seing as the flouricent of the screen that light up the screen to enable display visible.This top back light or botom back light as the name implies is positioned at the top and bottom side of the screen.It takes an expertize knowledge for one to be able to change the flouricent when comfirms bad.The same is applicable with Inverter.
Jan 06, 2011 | Proview PL913S 19" Flat Panel LCD Monitor
Screen trys to show desktop, but quickly fades to
Since the power led button is on, the problem with your monitor is the that the picture board of your monitor has develop fault, that is why it tries to show your desktop and quickly fades away.
The picture board of your monitor is bad and will need to be replaced in other for it to display.
The best thing for you to do is to take your monitor to a local repairer or any service center within your vicinity to help with the replacement of your picture board because the fault is not something you can fix on your own in other not to complicate issues.
Take care.
May 04, 2010 | ViewSonic VX924 19" LCD Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Monitor turns off after about 3-5 seconds
I would say your monitor is bad if you have tried it on 2 different monitors and it does the same on both. Check your warranty expiration date, some monitors have 2 or 3 years warranty. If it's still under warranty, you may be able to have it replaced or repaired.
Aug 14, 2009 | Samsung SyncMaster 920NW Monitor
The l226wtq goes black
Try shining a flashlight on the screen, or without the flashlight, try to see if you can distinguish anything on the screen at all, if you do, the backlight is dead, or the monitor has an internal most likely unfixable problem.
May 01, 2009 | Computers & Internet
Monitor fades and turns blue
this sounds like a transistor issue concerning the ccfl lamps the power transistors are deteriorating and they will eventually go bad you can have them replaced and that should fix the issue. otherwise I would say have the capacitors that feed the ccfl's may be getting old and need replacement as well, its not something the average customer will want to do but if you have a service center that does electronic repair then that would be bst.
Hope this helps
Jan 30, 2009 | Dell E171FPb 17" TFT LCD Flat Panel...
Monitor problem
Hi...there,
It's turns blue to power safe mode (yellow) it's prevent futher damaged to your monitor. It's seems you got a busted backlight inverter. Need to replaced a new one...Since you only got it for a few months, send it back to Acer for a replacement of a new backlight inverter... Have a nice day!
Oct 17, 2008 | Acer AL1916W 19" LCD Monitor
Hp1903 blank screen
power shortage maybe...try to plug your monitor on the other power supply,,be sure that your monitor is compatible on the voltage it required..
Aug 04, 2008 | HP vs19 (Silver) 19" LCD Monitor
Computers & Internet Logo
90 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
