Question about Trekstor DataStation maxi y.uh 400 GB USB Hard Drive
Slave hard drive not responding
I am using Microsoft vista an i can't see my slave hardrive
i tried restoring but still nothing,
    Genius:
  • 1,913 Answers
Reconnect your hard drive data cable and power cable then try again.
Posted on Oct 09, 2008
I am about to take a WD1600JD hardrive out of one PC and put into a newer PC as a slave hardrive. What should the poistion of the jumper be. Thanks
This is a SATA drive, and they don't use master and slave jumpers. They are serial devices, and each SATA drive is connected to its own motherboard connector. The master and slave jumpers are only on the parallel interface drives (with the wide data cable), since two drives could be used on the same motherboard controller. All you need to do is install the drive, plug in the power and data cables, and Windows will assign the drive a new letter.
Jan 05, 2011 | Western Digital Caviar SE WD1600JD 160 GB...
I have a Seagate ST3100011A drive 100 GB that I am trying to use as a slave. I removed the jumper per the manuel but I cannot get the drive to format. I have tried command prompt and device manager then...
You need to partition the disk first. Microsoft has a lengthy description of how to do this in XP at:
http://support.microsoft.com/kb/309000
Vista is at:
http://windows.microsoft.com/en-US/windows-vista/Create-and-format-a-hard-disk-partition
Vista & Win7 are almost the same procedure.
I don't get paid for advice so if this answers your problem, I would appreciate 4 thumbs.
Jim
Sep 20, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Massage appear no hardisk found
Try the following: 1. Try replacing the IDE cable or SATA cable of your hard disk. 2. Check the power cord if it is properly seated at the hard disk. 3. If you are using IDE hard drive. Check master or slave setting. 4. If you added a cd/dvd rom make sure it is set to a slave. 5. Try replacing another hard drive. Check if it works.
Thanks. More Power. Please rate. Let me know if you need further assistance.
Apr 26, 2010 | Maxtor Hard Drive
How do to install slave drive Seagate Barracuda 7200.9. Does it has to be to the motherboard or to a card in my computer? How do I set the pins in what order?
if y0our going to slave one hardrive you need to set that hardrive jumper into slave format....check your hardisk if where pin should it e placed...usually there is a direction where to set the jumper for slaving the hardrive.
Oct 28, 2009 | Seagate Barracuda 7200.9 ST3400633A 400 GB...
Restore Hardrive to Factory Settings, Missing Hidden Partition
Yes Claudia you are right. When you wiped the hard drive you deleted the partition that contained the systen restore (factory restore). You will have to purchase a new copy of Vista. It will not contain all of the other programs that came with your computer originally.
Before you installed Windows 7 it clearly states that you have to back up your system before you install it on your hard drive.
Why didn,t you keeep windows 7, if I may ask? If you made a copy of it (which you had to do when you insatlled it) reinstall it and use it. Microsoft will let you purchase it for $50.00, which is a lot less that what it will cost you to purcase Vista Home Premium.
Apr 20, 2009 | Computers & Internet
HARDDRIVE NOT BEING RECOGNISED
try manually configure the HDD to the BIOS setting.
input the drive parameters ( printed on the top of HDD)
next use the manufacturer disk tools of your hard drive ( download it to manufacturer web site)
Mar 23, 2009 | Western Digital 500GB My Book World...
How to detect the hardrive?
setup the first drive as slave ( sometimes No Jumper ) then the furthest away drive as Master.
If this fails, and you have 2 IDE Slots on the motherboard. ( Primary/Secondary ) Put 1 drive on primary as Slave. And DVD Rom As Master ( same Cable ) Then put second drive On Secondary IDE Slot. ( Set As Master Or Slave )
If none of these solutions Work For you, check to see if Both Channels are activated in the Bios.
Thankyou For Using Fixya.
Mike @ compurepair.
Jan 28, 2009 | Maxtor Hard Drive
PATA hd slave to SATA hd
Please one hard drive main disk and second one is slave so like this please remove the jumper for second one so first one is having the vista os (SATA) your computer will run normaly then attach the seond hard drive as slave (remove juper drive) you can see the dat (PATA)
Jul 18, 2008 | Computers & Internet
Hitachi 80GB hardrive - error 6
Install your previous hardrive as a slave, secondary drive to your new one, or easier still, buy an external enclosure for it and connect to it via usb
May 16, 2008 | Hitachi Deskstar 7K80 Hard Disk 80GB,...
DVD hardrive problem
Do you check the setting of your hard drive? It seems that you have already another hard drive (HD) install which is working already were your operating system install. Try to put the 2nd HD setting in slave position. Follow instruction that is written at the back of HD. Your computer should read the 2nd HD as slave and will see it as drive: F or G and so on.
Jan 11, 2008 | Acer Aspire T690 (AST690UP820A) PC...
Trekstor DataStation maxi y.uh 400 GB USB Hard Drive Logo
43 people viewed this question
Top Trekstor Computers & Internet Experts
Marcin
Lawrence Oravetz
Justin
Justin
Are you a Trekstor Computer and Internet Expert? Answer questions, earn points and help others
