Question about Panasonic KX-TGA560B 5.8 GHz Cordless Expansion Handset
Display backlit but does not display text
Phone seems to function fine but the display no longer displays any text. Back light works.
  • Anonymous May 11, 2009
    Same problem. Battery OK.
  • 1,913 Answers
Check you rbattery or cell .
reset your phone settings
Posted on Oct 09, 2008
  • ppn2k1 Jan 08, 2011
    How do u reset?
Clock and miles lates are not visualizti, the display does not work
Hi. It sounds like there was a voltage spike. I suspect that the crystal display has blown. This may be repaired at a electronics shop, or a new dash cluster would be needed.
Mar 22, 2014 | 2000 Volkswagen Passat 4Motion
Digital display not working
Do you know if your display is the VFD type (usually lights-up greenish-blue or amber on black,) or LCD (usually has a backlit backdrop with either black or colored digits)? Most are the VFD type and can dim over-time due to a resistor gradually changing value. Look on the board near the display, and see if a resistor appears to have gotten too-hot. I've repaired many displays on VCRs that have exhibited the same symptom. Hope it helps!
Apr 07, 2013 | Audio Players & Recorders
Backlite display on JVC sirius radio stopped working?
Typical Sirius junk - overheats and display goes out. Buy a new XM Onyx Plus radio instead.
Dec 28, 2012 | JVC KT-SR2000 SIRIUS Radio Receiver
Just got the phone today, it was acting fine until I disconnected the charger. Now the back light goes out after a couple seconds every time I try to use it. The light comes back on when I press the...
Try changing your display time out to something longer. Select menu-> settings-> display -> screen timeout -> pick something longer.
You can also set your brightness to not automatic. Within the same display menu, select brightness and uncheck the automatic brightness box. See if that works.
May 15, 2011 | Motorola Mobility CITRUS Smartphone
Toshiba P10 laptop screen no longer works.
It's not the inverter but the biotin backlight bulb that lights the display from underneath. The screen needs to be replaced unless you want to try and rebuild it and replace the backlight bulb. New screens from EBay should not be more than 70-100 bucks. If you want to try and replace the backlight bulb, the link is below for the procedure.....
Nov 03, 2009 | Toshiba Satellite LP154W01 Notebook
Nokia 3587i screen not displaying info
Your display circuit is broken, even if the LCD-panel,
seems to be ok the display is damaged.
This is a very common problem in Nokia phones.
The only way to fix this is to change the display.
You need a T-6 Torx Skrewdriver to do the job.
You can find displays for fair price at :
This is your solution! Please vote!
Feb 23, 2009 | Nokia 3587i
Display went from extremely dark to complely black
Hello there.
I understand that your Notebook is not showing the display lights. To isolate the issue please do the following troubleshooting steps.
1) Check the display with external monitor. If the external monitor is showing the display then the problem is with the LCD screen. If the external monitor is not showing the display then the problem is with the display card.
2) If you have any torch light or a cell phone , try focusing the light on the LCD screen after the Notebook is powered on and check whether you are able to see the texts and images on the LCD. If you are able to see the images and texts then it is the problem of the LCD back-lights. The lights which glow at the back of the LCD panel are not working.
If your Notebook is under warranty HP will repair it free of cost.
Contact HP customer chat center for more information regarding the details of the repair and the procedure for sending the Notebook to HP in case of repair.
For contacting HP chat support click on this link or copy and paste it in address bar of a web browser.
Feb 17, 2009 | HP Compaq Presario M2010US Notebook
Led display not showing any text
Sounds like it might be a motherboard problem...
Hope all is well.
Jan 20, 2009 | Epson Stylus Pro 4800 InkJet Printer
Mini display is backwards
I had this problem once, i just turned the phone off and took the battery out for about 5 min, and when i turned it back on it was back to normal
Nov 02, 2008 | Nokia 6085 Cellular Phone
Motorola RAZR V3m External Display Problem
Ive had 2 silver razrs and my first did the exact same thing it's a sensor intenally that wears out ecspecialy on the silver ones dont ask why? But i sent my back and replaced it. If you pay insurance everymonth like me use it!!
Jun 01, 2007 | Motorola Mobility RAZR V3
Panasonic KX-TGA560B 5.8 GHz Cordless Expansion Handset Logo
1,132 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
