I installed all new ink cartiges. now messasge is check BLK ink. code e02804, then turn off power? wg 8200 plotter
  • Anonymous Apr 04, 2009
    E02804
    Genius:
  • 1,913 Answers
Check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Posted on Oct 09, 2008
I HAVE A EPSON TX110 MODEL PRINTER BUT I WANT TO CHANGE INK CARTIGE TO TONER INK. IT IS POSSIBLE OR NOT.
No. Inkjets printers use liquid ink that is sprayed onto the paper through nozzles. Toner-based equipment uses powered ink that is electrostatically attracted to a metal drum then transferred to the paper and heat fused to it. The processes are completely different and require totally different internal hardware to achieve.
Sep 01, 2016 | Epson Workforce 1100 InkJet Plotter...
Canon W8400 E02804
Check x Tank (the ink color is indicated by x)
This is displayed when an incorrect ink tank is installed.
The final digit indicates the ink color.
So you have problem with Bk ink tank...
This is displayed when installation of an incorrect ink tank is detected.
This is displayed when a checksum error occurs in the ink tank EEPROM.
Ink tank, ink tank unit, engine controller, system controller
1. Replace the ink tank.
2. Replace the ink tank unit.
3. Cable connection check
Replace the cable between the ink tank unit and engine controller if the connection is not functioning normally.
4. Replace the engine controller.
5. Replace the system control
So as you can see there is a lot of possibillities, ... call service
Aug 08, 2011 | Canon imagePROGRAF W6400 InkJet Printer
The printer goes through the start up process and then gives the code on phaser 8560
Xerox Phaser 8560: Error Code 09,037.45 That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how hope this helps
Mar 16, 2011 | Computers & Internet
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
Cyan ink discharge at the back of the ink crtrige.
The leak is from the cyan ink cartridge or from the connections in the ink tube system. Replace the ink cartridge first. If that does not fix the problem, replace the ink tube system.
Jan 13, 2010 | HP DesignJet 1050c InkJet Printer
I got my ink cartridge refilled but it's still saying its empty, how do i get it to print anyway?
So as MUKHTAR states, do not refill cartiges when they are TOO EMPTY as most of the new printers have a sensor in the cartige that tells when it is empty. and when that sensor fills that the cartige is empty, it stays that way, no matter how much you refill it.
on the laser printers, when you refill your toner cartige there also is a chip that is changed (the sensor) because once that sensor feels that the cartige is empty you will not be able to use that cartige anymore.
Nov 26, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HP 750c+ plotter not responding
turn and unplug for 30 secs then open and remove / re-install each ink barrel according to your manual. You will have to go through the ink installation on your keypad one by one.
Apr 28, 2009 | HP DesignJet 750c plus InkJet Printer
Can you tell my printer cartiges was finish i refil new cartige and put in the printer but printer does not work only for printing from computer but fax is working photocopy is work and sccaner is also...
Please follow these tips
1. turn off your printer for one menu t and then turn it one.
2. You should charge your ink the option may be in your Pinter software or there should a button in your
Pinter to charge your ink.Press
OK to begin charging the ink.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}you need to disable the ink level monitors afterre-filling the cartridges. go to properties, maintenance, view printer status,option and click enable status monitor once
Nov 22, 2008 | Lexmark Office Equipment & Supplies
Kodak printer
pls make sure that there is no error in blk cartridge nor ther any warning symbol, ensure as well that you have installed corrctly and you can see the presence of the blk ink on your console. in other areas pls check when printing on the printer properties and select blk to identify what is the real prob.
we can start from here goodluck
Jul 29, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
118 people viewed this question
jasbo
jasbo
