Change the picture size on an aurex tv using the buttons on the side of tv
Hi managed to elarge the picture on the tv.picture is now too big for the screen.how can i restore it back to normal using the tuning butons on side of tv
I too have an Aurex TV ..and have to adjust the screen size regularly .I do this by the hand control.at the bottom of the handset are two rows of buttons..3 on the bottom row and 4 on the next row up..the on furthest on the right on the row with 4 buttons is the button for screen size change.
Posted on Mar 15, 2009
Hi I have the 42 inch Sony Bravia in my bedroom.The picture upstairs in the bedroom is too big for the tv if that makes sense.
Hello. It's not a picture setting, it's a format, or picture size setting. Look for a button on the remote labeled Format, or Size, or Zoom, or something similar. You want to select 16:9, or Full, or whatever fills the screen without zooming.
Oct 14, 2015 | Sony Televison & Video
Screen size is to big
On the TV remote look for a button that says Picture size, Aspect or Ratio and press on the button until you get the wide normal size.
Some cable TV remotes have the same functions, and you may need to check or call your cable TV company.
Best of luck
www.aaatvservice.com
May 23, 2012 | Vizio 42 in. LCD TV
Picture has become too big for screen
Used ur tv original remote,look for a button like View Mode,Picture Size,Aspect Ratio,Zoom.Pushes one of these buttons to changes the picture sizes to fit ur tv screen.
Jun 05, 2011 | Toymax Skyworth SLTV-2663A 26 in. LCD TV
Picture is too big, No remote to change size. Can i change the size from the front of the television?
Sorry, no. The only thing you can change is the color balance on your tv. Unless you can locate a "menu" button on the external of the tv this will be the only way to adjust picture size is within the menu.
Thank you!
May 27, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
How do I change the format on the screen to fit my TV, the format is too large and the picture is getting cut off on both sides
U using the tv original remote wright?Yes.Check ur tv remote control for a button like View Mode,Aspect Ratio,Picture Zoom,P.Size.Pushes one of these buttons to ajust the tv picture screen sizes.
Mar 25, 2011 | Televison & Video
My cable picture is too big for my toshiba plasma tv
How much to big? have you tried pressing the "Aspect" button on the remote to change the picture size? Futher adjust ments can be made by pressing the "Picture Pos./Size" button.
This information can be found on pages 22-24 of the Owners Manual. If you do not have you user manual here is a link to it:
Toshiba 50HP81 Owners Manual
Sep 18, 2010 | Toshiba 50HP81 50 in. Plasma Television
27 inch Zenith TV Vertical too big
If you are using a DTV coverter box, you may have changed the aspect ratio with your remote control. look for a button marked "aspect" or "picture size" use that to change size.
If you have a cable box, you may have a similar button.
Or you may find a picture size adjustment on your TV remote.
If you do not have "aspect" button on your remote try going to set up menu and look for picture size.
Older TVs used to have a vertical size adjustment at the back. look in the manual.
If none of the above, you have a biiger problem with the TV internal parts needing attention
Mar 03, 2010 | Zenith C27A24T 27" TV
My picture is zoomed in. Cannot go back to 'normal' and see everything. Credit names, etc are cut off on both sides.
Hi
Thanks for using FixYa. First of all please check your cable box settings first. Sometimes the remotes have a picture size button on them, and someone might have pressed that by accident. Check the TV settings, press Menu Button & then go to Window/Image size. Now select Full Size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Dec 26, 2009 | Sharp LC46SB57UN 46 in. LCD HDTV
How to make picture look larger?
HI,
You can resize your image by using microsoft picture manager.Please click on the below link to download it.:
http://www.brothersoft.com/microsoft-office-picture-manager-171868.html
After you download and install it.Just right click on the picture which you want to make big and then slect open with>Microsoft picture manager and then the image will open in it.After that on top click on Edit Pictures and on the right side a window will open up under Change Picture size click on Resize Image and then select the size you want to and click on ok/apply the picture will become big and then you just press Ctrl+S to save the image to your desired folder.
Thank You
Nov 03, 2009 | Polaroid GelCam DS-34 Instant Camera
Tv stuck on zoom
Hi
Thanks for using FixYa. Please check your cable box settings first. Sometimes the remotes have a picture size button on them, and the in-laws could have pressed that by accident. Check the TV settings, press Menu Button & then go to WINDOW/IMAGE SIZE. Now select normal size.
Also check the settings of the converter box (if you are using it). The boxes also have a peculiar problem: Unless users manually change settings from show to show, the picture from many stations either won’t fill the screen, or it will be so big that part of the picture is cut off by the edges of the screen. The solution is to press the “zoom” button on the remote that comes with the converter box. That will expand the picture so it fills the screen. If still the issue persists, then you’ll need to go to the service menu. To go to the service menu please start with the TV off and press mute > 1 > 8 > 2 > power the remote on. Now the TV will come on with the menu displayed and from there you can change the settings as required.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 27, 2008 | Televison & Video
Televison & Video Logo
169 people viewed this question
Top Televison & Video Experts
