Question about Frigidaire Dryers
I HAVE A YEAR AND HALF OLD FRIGIDAIRE DRYER MODLE #FDE437GHS! WHAT IS SOME OF THE MOST COMMON PROBLEMS WITH THIS MODEL? IT JUST WONT START! WE WERE HAVING PROBLEMS WITH THE START BUTTON BEFORE HAND! WE HAD TO PRESS IT A COUPLE TIMES FOR IT TO START! IF U COULD BE NICE ENOUGH TO SEND ME SOME OF THE MOST COMMON PROLEMS WITH THIS DRYER I WOULD BE REALLY APP. OR HOW WE COULD FIX THE START BUTTON?
  • Frigidaire Master
  • 19,396 Answers
From description, looks like the control panel assembly need to be replaced.
You find replacement parts and diagrams here.
Click here to get a list of common problems with this kind of appliance.
Posted on Oct 10, 2008
Frigidare electric dryer about a year ad a half old. When start button is pushed all lights on right side flash and unit beeps. Dryer does not run
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 03, 2011 | Frigidaire Electric Dryer
I have a Frigidaire Dryer Model#FEQ1442ES0
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Frigidaire Electric Dryer
I have a Frigidaire GLEQ2152ES 5.8 cu front-loading dryer. For the past year I have had no problems. Today I went to put in the first load and when I tried to start it I got nothing but 3 beeps. Even...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair ? The dryer will not start
heatman101
Aug 29, 2010 | Frigidaire Dryers
My frigidaire gallery model fsg748gfs gas dryer starts to heat up but stops after a few minutes?
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 22, 2010 | Frigidaire FGQ332ES Gas Dryer
It will not heat up 2 and a half year old gas dryer works perfectly just no heat
Dryer Repair - The
Dryer Repair - The
heatman101
May 14, 2010 | LG DLG6952 Gas Dryer
My frigidaire electric dryer wont heat up, only
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
heatman101
May 11, 2010 | Dryers
Squeaky 4-yr old Frigidaire gas dryer
it's most likely the rear bearing that the drum rides on in the rear of dryer,you'll need the model number located around the door opening to order the right part.
Apr 25, 2010 | Frigidaire Dryers
My gas dryer (3 yrs old today) wont turn. It just
O turned the drum by hand and it started running
Nov 04, 2009 | Frigidaire Dryers
Frigidare Gas Dryer - get some heat, but NOT hot enough!!
You say its a gas dryer...there is no element. Have you cleaned the lint trap. Is the vent clear of obstructions? I suspect one of these issues will be the problem
Mar 16, 2009 | Frigidaire FGQ1442ES Gas Dryer
Dryers Logo
70 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
