Question about Refrigerators
Have a whirlpool side by side #ed5ftg. will freeze and cool only when set at the coldest setting. Fans will not run for very long at any other setting. Defrost timer has been replaced. Can anyone help? Thanks
  • powerwagon1 Dec 27, 2008
    fan is intermittantly running . suspect a fan problem same unit EDFTG . Any comments ?
    Scholar:
  • 142 Answers
You need a new thermostat. Good Luck!
barneyluc
Posted on Oct 10, 2008
Model ed5ftg problem: freezer inadvertently defrosts on its own.refrigerator remains cold.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 07, 2010 | Whirlpool ED5FTGX Side by Side...
My Whirlpool Refrigarator isnt cooling or freezing. Its running but there is no cool air on either side. Ive adjusted the temperature control to the coldest setting but still nothing...what could the...
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 12, 2010 | Whirlpool GD5SHAX Side by Side...
Pull the lower front panel off. Inside you'll see a round small timer with a screw slot in it. Turn the screw slot slowly to the right (clockwise) only, until you hear a slight click. Wait five minutes and feel the walls of the freezer, they should be getting cold by now. If so, you need a new defrost timer. Thank you, Dana
Mar 26, 2010 | Whirlpool GD5SHAX Side by Side...
My ED5FTG Whirlpool refrigerator is not freezing!
CHECK STARTER DEVICE. PARTS NUMBER:2220477
Mar 24, 2009 | Refrigerators
Unit ED2FTGXKQ04, side-by-side fridge not cooling
hello my is leroy, have u check the freon levels for the unit.
Mar 08, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer compartment of refrigerator not freezing
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
So, how can the Ref side be cold and the freezer side not freezing?
1. Coolant leak. There is enough coolant to keep the Ref side cool but not enough to freeze on the freezer side.
2. Defrost system failure. The coils on the freezer side are clogged with ice and it's just a matter of time when the Ref side won't cool either. The back wall in the freezer will be covered with ice/frost
Jan 09, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Refrigerator side is freezing contents
If your settings are right then the cold control switch is the problem
Dec 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer not cold but fridge is cool
quickest and cheapest way is to switch the unit off overnight. possibly missed a proper defrost cycle and evap.coil is blocked. when properly defrosted,switch on and you could be back on line
Aug 09, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
69 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
