Question about Lexmark X2500 All-In-One Printer
Printer jams Everytime I try to print something the printer jams. It always jams to the right side as soon as it pulls in the paper. What can I do? Does it need cleaning or?????
I has a problem like this too. What I did is I checked the paper feeder by putting my hand in it (while turned off) and I found a ballpen cap.
Posted on Feb 09, 2009
How do I get jammed paper out of the back of it?
This is from the user guide available on the website:
This section contains the following topics:
• Clear paper jams
• Avoid paper jams
Clear paper jams
Paper jams can occur either inside the printer or in the automatic document feeder.
CAUTION: To prevent possible damage to the printhead, clear paper jams as
soon as possible.
TIP: If you notice poor print quality, clean the printhead. For more information, see
Clean the printhead.
Use these steps to clear a paper jam.
To clear a jam inside the printer
1. Remove all media from the output tray.
CAUTION: Trying to clear a paper jam from the front of the printer can
damage the print mechanism. Always access and clear paper jams through
the automatic two-sided printing accessory (duplexer).
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the unit.
b. Locate any jammed media inside the printer, grasp it with both hands and
then pull it towards you.
c. If the jam is not there, push the latch on top of the duplexer and lower the
cover. If media is jammed inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the printer.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and
remove the jammed media, if possible. If not, do the following:
a. Ensure the printer is turned off and disconnect the power cord.
b. Lift the printer off Tray 2.
c. Remove the jammed media from the bottom of the printer or from Tray 2.
d. Reposition the printer on top of Tray 2.
5. Open the ink cartridge access door. If there is paper remaining inside the printer,
ensure the carriage has moved to the right of the printer, free any paper scraps or
wrinkled media, and pull the media towards you through the top of the printer.
WARNING! Do not reach into the printer when it is on and the carriage is
stuck. When you open the ink cartridge access door, the carriage should
return to its position on the right side of the printer. If it does not move to the
right, turn off the printer before you remove any jam.
6. After clearing the jam, close all covers, turn on the printer (if you turned it off) and
resend the print job.
That's about as much as I can find for you. If you look in you user guide which is on a CD that came with the unit, you can go to page 152 through 154 to see diagrams that go with these instructions. Good luck!
Nov 13, 2014 | HP CM749A - Officejet Pro 8600...
Paper jam always.
Helo have you tried to check on the driving gears it but try to call your technician to check on it otherwise you may spoil your printer
Jun 16, 2017 | HP PSC 1610 All-In-One InkJet Printer
Everytime I go to print something the paper get's pulled to the right and becomes jammed. Why is this? And how can I fix it?
Seems to me that there is something blocking the paper path. Perhaps a paper clip or a pen ? Is there an access door on the rear of the printer. If so, open up and check to see if the jammed paper is hitting something or has a "dent" in it where it's hitting the object. Good luck .
Dec 06, 2010 | Epson Stylus CX4200 All-In-One InkJet...
Says there is a paper jam everytime i try to print
Check within your paper feeder rollers there might be something stuck inside it like paper clips, coins or anything small and solid. If you can find way to open the printer without braking it, that would be nice.
Hope this helps.
Jan 12, 2010 | Canon PIXMA MP180 All-In-One InkJet...
Printer pulls paper to right side jams does not print
usually this indicates some foreign object on the opposite side where the paper goes in. Please check to see if you have some small pieces of paper or something else in the paper path area.
also, another possibility is that your pickup roller is missing, dirty or damaged. try cleaning it too.
thanks adi
Dec 01, 2009 | HP Deskjet 3845 InkJet Printer
Printer jams
try to clean the printer rollers with acohol it should work
Jul 23, 2009 | Office Equipment & Supplies
Paper feed problem from both tray 1 & 2
There is a long set of sensor flags on the bottom of the paper input unit that can get stuck and not move freely. This will cause jams from both trays. Try unplugging the printer, removing the toner cartridges and tray 2. Turn the printer on its back or side. You will see a long, black plastic bar with flags on it that runs the length of the paper input unit. make sure it moves freely.
Feb 17, 2009 | HP LaserJet CP3505n Printer
Printer always jams
check your toner cartridge and also u need to service the printer fuser aseembly.also change roller.or taplon tape.
thats all
also see there is not any paper jam in parts.
Oct 09, 2008 | Lexmark X2500 All-In-One Printer
Paper Jam
i did exactly as iamzwalrus said and it fixed.go with that if nothing eles works.
Apr 24, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Do not continue this way, you are sure to ruin your paper sensor or the like. Most probably you have a paper jam inside near the carriage or roller. Open at front, check inside for paper jam.
Jan 22, 2008 | Canon PIXMA MP180 All-In-One InkJet...
Lexmark X2500 All-In-One Printer Logo
87 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
