Question about Sony KDF46E2000 46" Projection HDTV
Too much windex sprayed onto screen of Grand wega- black blotches
When my back was turned today for a few minutes today my 5 year old Granddaughter decided to do some house cleaning with the bottle of Windex and a cloth. She not only did the coffee table and glass tables but she also sprayed and sprayed and sprayed the front of my 46" LCD monitor which subsequentially ran to the bottom of the screen and sat in three puddles along the bottom,behind the face plate. Right now I have three large black ( liquid) splotches along the bottom.,and underneath of the glarescreen., I'm hoping they will dry out, but what it really needs is for the cover to come off this monitor ( large plastic face plate over the LCD screen under neath) so it can be cleaned or repaired properly. Anyone had a situation like this? Can it dry by itself? Is the cover readily easy to come away from the housing?
Thanks for your kind words and suggestions.., It turned out,, That after 12 days it finally cleared totally away and I now have no spots., or black spots. It started to disappear after a couple of days but took more than 10 days to appear to be evaporating..
Posted on Nov 11, 2008
    Novelist:
  • 135 Answers
That's not the worst that can happen, imagine what smoke can do! I hope it didn't seep further into the set.
There are two screens sandwiched together which is why the puddles formed. Now the real problem is that they can be easily damaged if separated and slide the least little bit. One has a very fine fresnel pattern that looks like a giant thumb print if held up to the light by itself. This is the one that always gets damaged by fingernails or touching anything else. Oh, you do need a carpet, dust, pet and human hair free room so the static doesn't cling to the panels as you tape them back together after cleaning. You have to get the panels back together with the right sides facing each other and in the proper orientation or your picture will suffer and you will have to figure out how you went wrong.
Forget ordering a set of these panels as the cost is pretty steep and you still have to deal with knowing how to properly orient them, as it isn't intuitive. Even the trained techs dread this particular job because the fresnel panel is so easy to damage or you wind up with lint or hair between the panels. So if you're thinking you'll leave the job to the professionals, realize through no fault of their own, even they have problems replacing the panels.
Wow, you're still reading?!
No easy fix here, see what happens over time as the solution evaporates. If you don't like what you see, this is your opportunity to pitch for a new flat panel LCD TV! Your granddaughter will make a fine wife some day, by then projection will go the way of 8 tracks. ;-) Teach her to use only LCD cleaner on a microfiber cloth for all the electronics as windex or ammonia products can yellow plastics.
My Sony 54" Grand Wega rear projection TV is 4 years old in Sep. It has started losing picture and sound for a few seconds then comes back on. It is getting more and more frequent. . . like six times in 5...
A spent bulb will cause the whole set to go off. If you have not changed the bulb in all of these years, first you are lucky, and second that is probably the cause of your problem.
Aug 23, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
60 grand wega 5 years old picture getting darker
souns like an over heating isue
try cleaning out the unit
take it to the local mechanic have him give your tv a ******* (with compressed air )
heck hes been screwing you so his kids can go to coledge for years whynot get a freebe?
Aug 04, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand Wega KDF_60XBR950 turns itself off
Symptom shows its time to replace Lamp.
How old is this TV?
Apr 14, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Tv turns off
Its the lamp that needs replacing. It will run for a couple of seconds and then it would dim or turn off.
May 27, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDF46E2000 46" Projection HDTV Logo
329 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
