Question about Mitsubishi Mr. Slim MXZ30TN Air Conditioner
Unit does not work
I have a split system 12N, installed in April 2007. I had turned off the heat with the remote two days ago. Today I cannot get any response. I have replaced the batteries, tried the reset button, turned the breaker off and on, and even pulled the fuse for the outdoor unit and replaced it. When the outdoor fuse was replaced, the outdoor unit clicked so I think the problem is in the indoor portion.
    Habit-Forming:
  • 109 Answers
All the mitsubishies had auto diagnosis,you must set up with the remote control to see the code and how many times blinking the button to the indoor unit.
Posted on Jul 09, 2009
Where can I get an owner's manual for unidentified air conditioner?
look on cover or inside cover of unit for id tag or a control panel then use that information to look up on line for a user manual or order one ---when ordering remote what information was used to get a correct on --should be able to find unit information from remote like as to what unit it goes to
Apr 18, 2017 | Heating & Cooling
I have a Vulcan Bonaire ducted heating system with Comfort Control in a holiday house, installed in 2006. It was working fine last time we used it about a month ago. Today every time I try to turn the...
hi,
The heating coil itself have some problem that's why the circuit breaker clicks off by sensing over current drop. Check the heating coil and replace it.
ok
Jun 11, 2011 | Heating & Cooling
Have an LG split system air conditioner. No way to turn it on or off on system. Remote only and it is not working. Did this a week ago and changed batteries, took a while before new batteries worked as...
Before buying new one, try with this step. Remove batteries from your remote and reset it after 5 minutes. And also remove DC wires plugged to indoor sensor display, and after 5 minutes re set it again. Now start your unit. Sometimes it will work out. Thanks.
Feb 02, 2011 | LG LSC121PMA Split System Air Conditioner
AMCOR 24,000 BTU split system. Worked fine two years, then today it had no power. Checked circuit breaker, it had popped. Reset CB and went to inside unit - would not turn on or off with remote or hard...
I had this same problem. I disconnected the thermostat wire out side at the condenser and reconnected it and it started working. A couple days later it blew the breaker again this time I found the bus where the L1, L2. GR wire connect at the condenser had melted. I wire nutted all 3 wires instead of the using the bus everything is working right again. Hope this helps.
Tim
Aug 09, 2010 | AmcorAire UCHW-H24AF2 Split System Air...
LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
First check your circuit breaker or fuse that supplies power to the outside unit. It's probably separate from the inside unit. Then try to turn unit on. If the fan and compressor just make a humming sound then turn it off and check the capacitor if you have a multimeter. You can also look at it and see if the top looks expanded. That's a good sign its bad, but not all bad one's look expanded. Tomorrow I will have access to an LG service manual and can let you know what the code means. Sorry I can't get it sooner. Let me know what you find.
May 02, 2010 | LG LA185HV Split System Air Conditioner
Split system outside unit won't come on for cooling, only heating
Check your filters, dog hair and lack of maintenance will definitely burden the cooling mode of the Mr Slim units.
Aug 22, 2009 | Mitsubishi Heating & Cooling
Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
Mitsubishi Mr. Slim MXZ30TN Air Conditioner Logo
258 people viewed this question
Top Mitsubishi Heating & Cooling Experts
vince
D. E. Hev
Stuart Slabber
Level 1 Expert
Are you a Mitsubishi Heating and Cooling Expert? Answer questions, earn points and help others
