I need screws for my Gateway S7200C. ALl I need are four tiny screws that hold the hinge onto the tablet laptop....
    Scholar:
  • 54 Answers
Hi stealthsand,
I would suggest you locate your local computer fix-it shop, Geek Squad(watch these guys they try to make a fortune out of every sale.)They should have the screws you need. I hope this helped.
Thanks for using FixYa.com
Sincerely, cyyyd7
Posted on Oct 09, 2008
The "n" key on my laptop has all of a sudden become floppy - how do i fix or replace?
Under the N key there are tiny plastic hinges. Align the N key with the B and M keys then press down on the N key until the key clicks onto these hinges.
Jan 10, 2013 | Gateway nv Computers & Internet
Gateway M275 display scambles
I suspect it may be a problem with the video cable coming from the convertible tablet, up through the hinged support for the LCD screen, AND/OR the screen Inverter.
I would like you to connect a VGA monitor, to the VGA port on the back of the convertible tablet. The VGA monitor will now be an External Monitor.
[ Looking at the rear of the convertible tablet, start at the Left side.
Vent, USB port, Monitor port. The Monitor port is the VGA port ]
The VGA monitor can be a CRT type, (Looks like a small TV), or a flat LCD screen monitor with a VGA cable.
Notebook OFF, monitor OFF, connect the VGA monitor to the M275's VGA connector. (Port)
Turn the monitor on. If a CRT type, allow it to warm up.
Turn the notebook on.
By the factory default settings, whatever is shown on the convertible tablet's internal monitor, should now be shown on the external monitor.
(VGA monitor)
If not, press, and hold down on the Fn key (On the bottom row of the Keyboard, all the way to the Left), and tap once on the F3 key.
(Top row of Function keys. The F3 key is the Display Toggle-Over Key )
No graphics shown on the external monitor? Hold down on the Fn key again, and tap the F3 key again.
There are at least three options available;
1) Convertible tablet's internal monitor - ONLY
2) Convertible tablet, AND external monitor
3) External monitor - ONLY
If graphics are fine on the external monitor, you have a problem with the video cable, and/or the screen Inverter. At this time we will bypass the LCD screen, and come back to it.
At the bottom/middle of the tablet's LCD screen, is the Hinge. The Hinge Cover is 'T shaped', and has one single Philips screw holding it on.
If you remove the screw, and the Hinge Cover, you will see two wire harnesses.
One Black, the other White.
See that these two cables are plugged in tightly to the connector.
After checking this step come back in a Comment, and state your findings.
Regards,
joecoolvette
[ Additionally;
Here is the Service Manual (Free) for the Gateway M275 Convertible Tablet,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-gateway
Where it states - Gateway 400, go down to the second line, and across to M275. Left-click on M275.
This is a PDF file. It may take up to 30 seconds before the first page comes up.
Dec 11, 2011 | Gateway M275 Tablet PC
Need hinge for my tb 120 gateway laptop
Replacement hinges for Gateway laptops on the Internet are available fron this site :-,
http://www.laptoprepairco.com/Search/hinges/hinges.asp
Aug 11, 2010 | Gateway Tablets & eReaders
Broken swivel hinge on Gateway m280e laptop.
not sure about documentation - but for parts you might try dakotapcwarehouse.com - my company has found parts for a lot of its older gateway laptops there
Jun 03, 2010 | Gateway M280E
How do I replace the bezel and LCD back cover on my DEL laptop?I can't get the LCD screen or the "hinge" to come apart so I can replace the bezel around the screen as well as the back cover that has the...
aound the screen in the plastic area there should be four plastic stops, very tiny, in each corner, there's screws under those rubber stops. use a tiny screw driver to pop them out, don't loose 'em now. after you remove the tiny screws, just pop the front face plate out with a small flathead screwdriver.
Sep 15, 2009 | Dell Latitude D610 Notebook PC
BROKEN HINGE GATEWAY LAPTOP TB120
search "gateway e-155c lcd swivel assembly" on google or any other search engine and you will find the part that you need.
You will need to do your own replacement, but that is the part that will fix your problem
Mar 28, 2009 | Tablets & eReaders
Replacing Laptop LCD Screen
you'll need to remove the screws holding the screen bezel (the plastic around screen) on...they'll probably be under little circular plastic or rubber covers....gently pry these out as they'll go back in place when you reverse the procedure....should be four of them....Gently pry the bezel away from the main screen housing ...once thats done....you'll need to unscrew the screws holding the screen onto the hinge plates...(again should be 4 of these)...screen should now be free
NB be careful when screwing in the new screen to the hinge plates as overtightening can sometimes crack the screen
Dec 15, 2008 | Compaq Armada E500 Notebook
Gateway Table PC Cx2620 Screen Wobble
Unplug and remove the battery pack for safety. DOn't want any shorts to happen. With the laptop open, gently pry with a very small blade the plastic cover at the front of the swivel and remove. It is in two pieces...front and back. It is OK to leave the rear half in place. Once removed you must close the laptop again. You will now have access to the screws on the hinges. Use a small Robertson screwdriver to tighten the screws. Snap the cover back in place....Voila!. IF the screws are broken (like mine were) remove all the good screws, gently lift and move the screen slightly forward, remove the broken screws with some needle nose pliers. Reassemble with new screws. I found some screws at the local computer geek shop in his selection of random screws. THey are quite tiny. CHeck Future Shop if they are in your area as they deal and repair Gateway so you may have a better chance of finding some screws that work. Good Luck.
Nov 18, 2008 | Gateway Convertible CX2620 Notebook
Gateway M275 Screen Wobbes
There are 4 screws on bottom too.
Aug 24, 2008 | Gateway M275 Tablet PC
Broken screen hinge/collar
You can purchase replacement hinges and hinge covers here: http://www.mundocorp.com/m275.html They may be a bit of work to replace. But short of replacing the hinge assembly, it doesn't sound like that is going to move.
Aug 28, 2007 | Gateway M275 Tablet PC
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
