Code for TV
Need the codes for Sony KDL_46XBR5 TV using Big EastHT, One For All remote
  • 520 Answers
Here's the link to one for all's website.
http://www.oneforall-na.com/advanced_search.php
Posted on Oct 10, 2008
Need remote code for sony bravia-model KDL-26M4000 using oneforall remote URC-4640B00.lost sony remote
Below is a list of all Sony TV remote codes. I really suggest you use the code search function of the remote.
Sony 0000 1505 1651 0011 1010 0036 0650 1100 1925 0102 0353 0111 0037 0080 0556 0157 0834
Jun 19, 2017 | Sony Televison & Video
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Need a remote contol code for sony bravia kdl 37U4000 for skyplus HD remote control
Hello
Remote codes for Sony TV with Sky Plus remote are:
038
533
679
505
533 038 039 064 102 130 505
Ok.
Jul 06, 2011 | Sony BRAVIA KDL-37U4000 37 in. LCD TV
When the TV is turned on, the right 2/3 of the screen is very dark. ... Make: Sony Model: KDL-46XBR5
The T con problem with your TV. Please repair and or replace the defective parts.
Regards, Jay
Feb 26, 2011 | Sony KDL-46XBR5 46 in. LCD HDTV
Code for Channel Master CM-7000 Digital TV converter box ? I need code number for Sony TV
If you do the setting up using device codes scan correctly (page 25 in the user guide ) it worked with my sony bravia KDL-32L5000.
Oct 26, 2010 | Channel Master (9537) Remote Control
I have a KDL 46XBR5 which displays horizontal lines across the screen for approximately 5 minutes after turning on the TV. Is there a fix for this problem?
The reddish blotchy screen also had a series of horizontal lines/sections of screen on occasion. I was able to determine that the ground wire screws were loose (loosened and retightend all of them) and a few of the connections between boards (the wires/plugs) were loose. Seems to have resolved the issue without having to replace any boards/caps etc. I would try this free 20 minute fix before searching out a new board.
Jul 28, 2010 | Sony KDL-46XBR5 46 in. LCD HDTV
Need remote code for TV Sony Bravia KDL-46W4500
I tried out a few of the numbers that were posted and the "0000" number worked.
Thanks anyway
Jan 03, 2010 | Yamaha YSP-1 System
YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Jan 19, 2009 | Yamaha YSP-1 System
Remote code for Sony KDL-52WL35 LCD TV
need the code for the sony 1080 tv please
Mar 09, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
