Question about Motorola Mobility RAZR V3
Display time and date
How do i display the time date on the main screen
  • billcheta Nov 02, 2008
    I can't find a way to reset the clock from daylight savings time to central time.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
Go to your phone's "Time & date" settings and select "show", u might have your date and time hidden this time. And more thing, set the time and date first, some phones displays time and date automatically after setting...unless the user choosed to hide it...good luck! i hope this solution solved your problem.......
Posted on Oct 10, 2008
2 Suggested Answers
  • 833 Answers
SOURCE: Date and time stamp on my home screen
Jack,
There is no universal answer here. It depends on whose network your phone is on. Each has their own display software. I looked on my Sprint unit and couldn't remove it.
Posted on Dec 05, 2007
Setting the date and time
After selecting 1, type in the date mm/dd/yy (it doesn't appear on the screen) then press hold/save. Then type in the time again it won't appear on the screen press hold/save. It will then return to the main screen with the correct time and date. Hope this helps.
Oct 16, 2012 | LG Ericsson LIP-8012D 12 Button IP Phone
Tip
Checking Software Version
To check the phones software revision for Nokia Mobile.
On the main screen type *#0000#
To enter in the secret menu in Nokia Phone.
On the main screen type *#92702689# [*#war0anty#]
It will take you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
on Apr 02, 2010 | Cell Phones
Change time
1. Begin on the main sales screen
2. Press the purple MORE key twice
3. Choose OTHER SET UP from the display screen
4. Type in your password if applicable
5. Press the purple MORE key until the display reads SET DATE/TIME
6. Choose SET DATE/TIME from the display screen
7. Type in the date mm/dd/yyyy
8. Type in the time HH:MM:SS in Military Time
9. Press ENTER
10. Press the red CANCEL key
Mar 11, 2012 | VeriFone VX510
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
Can't get date/time to not appear on screen or download to comp
Are you sure your canon battery pack is OK?If not ,replace it with a high quality replacement battery pack.
Jul 25, 2010 | Canon PowerShot SD1100 IS Digital Camera
Xerox workcentre Pro 575 How do I change the time of day setting
  1. From the Standby Mode, press the [Menu] (up arrow) button, then press [4], [2]. The screen will display: Date.
    [01-31-2000]
  2. Use the numeric keypad to enter the date and the arrow buttons to move between the fields, then press [Enter]. The screen will display:Date format.
    1. MM-DD-YYYY
    2. DD-MM-YYYY
    3. YYYY-MM-DD
  3. Use the numeric keypad to designate the Date format you require to use. The screen will display: Month format.
    1. Numeric: displays the month with a number
    2. Name: displays an abbreviated month name.
  4. Use the numeric keypad to designate the Month format you require to use. The screen will display: Time format?
    1. 24 hour
    2. 12 hour
  5. Use the numeric keypad to designate the time format you require to use. The screen will display: Time.
    10:30 pm (or 22:30 pm if you chose the 24 hour format).
  6. Use the numeric keypad to enter the time and the arrow buttons to select [AM] or [PM], then press [Enter].
  7. Press [Exit] or [Stop] when the menu selection screen displays to return to the Standby Mode.
Nov 20, 2008 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Time Display on main screen
Possible with all cell phones.
Go to settings. set time and date, click on show time and date and click ok.Whoala! you have a time on main screen. If you have trouble go to nearest retailer they can help you for free.
May 31, 2008 | Samsung SGH-D900 Cellular Phone
Time
go in the settings n then phone settings then display settings n then there will be an option to show date n time on the main screen
May 24, 2008 | LG KU990 Viewty
Jack,
Dec 05, 2007 | Motorola Mobility RAZR V3
No date display
yep i have the same problem too. no date display. it displays the date on the outer screen when i flip the phone shut. but not on the main screen when it is open.
Jun 18, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
256 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
