Question about Hitachi P50H401 50 in. Plasma HDTV
Change from 480 pixles to 1080 how do you do it ????
Im trying to make a xbox 360 come in in hd but it says my tv is set to 480 pixles i need to know how to set it to 1080
  • 29 Answers
Do you have the HDMI out in your Xbox??
The input is auto switching for the resolution.
Posted on Nov 28, 2008
  • app_3rp53627
    app_3rp53627 Aug 30, 2012
    i have the same problem. i put in a hdmi cable but it shows nothing and can't edit the hd settings on my xbox.
How do i hook up my sharp 27f543e to my Xbox 360 using component cables every time i turn the HD switch on it jumps to a static mis-colored screen.i try to change it back from 720 to 480. is it just not...
U using a stantard tube tv,that why.It is an analog tv.It can't scan in high resolutions as ur Xbox require.That,why it reverse back to the resolution it can and able to scan the lower resolutions.
Dec 04, 2010 | Sharp 27F543 TV
Xbox 360 Screen Flashing
is your xbox set for 1080 p and are you sure your tv can handle 1080p
Mar 12, 2009 | Microsoft Xbox 360 Console
Playing dvd's at 1080 resolution with xbox 360
The 360 will upconvert DVDs to 1080P only through a VGA cable or an HDMI cable.
Dec 11, 2008 | Microsoft Xbox 360 Console
My xbox360 Wont work on my WS-55513 MITSUBISHI COMPONENT
Try changing the settings on the Xbox under display to 1080i. If it is 1080 p, or 720p, the image will look funny so make sure it is at 1080i.
Your welcome
Your friend from down the lane!
May 21, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Phillips hdtv
if the cable box is sending in 1080 signal the tv will not be able to format to a 480 (you can switch to either/or)
the problem you have is if your not sending 1080 to the tv your not really watching HD but you cant strech the 4:3 (non HD channels) to the 16:9
the only thing you can do is run analog signal and a digital signal then switch between the two sorces for your HD and non HD programs
Mar 11, 2008 | Philips 42PFL5332D 42 in. LCD Television
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Screen resolution
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console.
Change your display output settings from this screen. Display settings include screen resolution and screen dimension (or aspect ratio, either standard or widescreen).
In some cases you can select an "Optimal Resolution" button, which appears only when Xbox supports the native resolution of the TV or monitor and automatically applies the best setting but that might not work with your tv.
If you are using VGA you must choose from among the following output resolutions: 640 x 480, 848 x 480, 1204 x 720, 1280 x 720, 1280 x 768, 1280 x 1024, 1360 x 768, and 1920 x 1080.  Much like a PC you would want to select a lower resolution (640X480).  That will make your fonts larger.
Screen Format: The default setting is Normal (a standard 4:3 aspect ratio); select Widescreen to change the output aspect ratio to 16:9 if you have a widescreen TV or monitor.  You should select normal and not widescreen for a standard tv.
Hope this helps,
Bob
Dec 26, 2007 | Microsoft Xbox 360 Console
Can't get my TV to go to 1080i
Your tv is either 1080p or not 1080 compliant. Try 720p or you may be forced to keep it at 480
Dec 25, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Can you connect to upconversion DVD Player for HDMI performance
The TV supports 1080i so if your hardware is plugged into the Component Cable Connection for Digital TV on the back the signal will come out 1080i as long as the hardware supports the size.
For example, my 360 is connected like this and when the dvd player is in use it upscales from the 480 format dvds use to 1080. More on the HD-DVD for the 360 and how it handles the sizes here:
http://www.engadgethd.com/2006/09/21/xbox-360-hd-dvd-playback-maximum-1080i-via-component-1080p-vga/
Kind of an old article since the newer 360s have hdmi and support 1080p that route.
Hopefully this helps.
Dec 16, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Hitachi P50H401 50 in. Plasma HDTV Logo
384 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
