Question about Casio Parts Cash Register PC Desktop
Casio 3708ER i have a casio 3708ER when i switch it on the screen reads 0.00000000 all it will let me do is press 1 number at a time like 0.000000001 or 0.000000011 it wont let me put in a combination of numbers and if i press any other keys it screams can anyone help please as i have no manual thanks
  • 737 Answers
Hi.
It sounds like you have lost all of the programming from the machine. Have you had the machine regularly serviced? If the internal battery hasn't been changed in the last 4 or 5 years, then you have probably lost everything. Since these machines are so old, it won't really be worth spending any money or time on it. Most parts are very worn in this model now, so you will soon be looking at print head or motor failure. There may be a lot of programming to go back in, and it would need to be stripped down for battery rplacement. You would be better off to buy something newer for the same price as the repair.
Mark
Posted on Oct 10, 2008
A mod B in Casio fx-115MS How to get an m mod n (ie to calculate modulo of a number)
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate m mod n, calculate m-m/n*n. No shortcuts, no rearranging. That's m minus m divided by n times n. You have to enter both numbers twice, but you will get the modulus.
Press MODE 1 to return to your previously scheduled calculations.
May 30, 2011 | Casio FX-115MS Plus Calculator
How to find A mod B in casio 115MS
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate A mod B, calculate A-A/B*B. No shortcuts, no rearranging. That's A minus A divided by B times B. You have to enter both numbers twice, but you will get the modulus.
May 20, 2011 | Casio FX-115ES Scientific Calculator
I am unable to find the modulo of the numbers
It's a bit convoluted, and it only works for integers. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate a mod b, calculate a-a/b*b. No shortcuts, no rearranging. That's a minus a divided by b times b. You have to enter both numbers twice, but you will get the modulus.
May 08, 2011 | Casio FX-115MS Plus Calculator
As the Casio FX-991es Plus got a modular function if not this there away of performing mod on it.
It's a bit convoluted, and it only works for integers, but here's one way. Press MODE 4 to switch to BASE-N (integer) mode. If the screen doesn't read "Dec" then press the x^2 key. Now, to calculate a mod b, calculate a-a/b*b. No shortcuts, no rearranging. That's a minus a divided by b times b. You have to enter both numbers twice, but you will get the modulus.
May 03, 2011 | Casio FX-115ES Scientific Calculator
What is the symbol of mod key in calculater
There isn't one. It's a bit convoluted, and it only works for integers, but here's one way to do it.
Apr 14, 2011 | Casio FX-115ES Scientific Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
I want to know how to perform modulo operation
Nov 09, 2010 | Casio FX-115MS Plus Calculator
Can i do statistics on the casio fx-115 es? and how can i use it?
Yes and here is how to do 1-var statistics and 2-var statistics. Please read the whole post. I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
Nov 06, 2010 | Casio FX-115ES Scientific Calculator
How to get a Casio out of rounding mode
Press the MODE key a certain number of times, until you reach a screen that displays FIX SCI NORM and numbers 1, 2, and 3 under them. Press 1 key to select the FIX display format, then enter a number between 0 and 9 to set the number of decimal digits you want to keep in your result. In your case the calculator is already rounding so you should select a reasonable number of digits say 2 to 3.
MODE (a certain number of times ....) 1 (FIX) 3 will keep three decimal digits in the results.
Sep 14, 2010 | Casio FX-300MS Calculator
Calcuator Setup
Press [SHIFT][MODE] to open (SETUP) screen. See screen capture.
Select [6:Fix] and when you are prompted to enter a number between 0 an d 9, type in 1
Jun 28, 2010 | Casio FX-115ES Scientific Calculator
Casio Parts Cash Register PC Desktop Logo
75 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
jackcity
jackcity
Level 1 Expert
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
