Question about Sewing Machines
Toyota sewing machinge 5500
The bobbin wont wind. The motor runs but the bobbin does not turn to wind the cotton on
  • laksravi2002 Oct 31, 2008
    i have the same problem ,bought this machine in US & tried using in INDIA everything is working except this bobbin winder.can u solve this problem.im using a adapter.thanxs in advance.
If I understand the problem, the bobin winder has probably lost a rubber 'o' ring.
Unscrew the two top screws and remove the top cover. At the base of the bobin spindle is a metal disk that should have a rubber 'o' ring on it. This will perish over time and break off.
When the bobin winder is pushed sideways into the active position, this should contact the main turning handle thingy (that's a technical term) and be spun around. Check if the bobin 'o' ring is making contact or if it is even there at all. Any sewing machine repair shop (or good automotive store if you're desperate) will have a replacement.
Posted on Dec 06, 2008
I had this problem and fixed it by using a little double stick tape (or just fold over some normal tape) I gently taped the bobbin to the base of the shaft and then I didn't have any problems winding at all. The main problem was anytime there was even the least amount of tension on the thread, the shaft would spin but the bobbin wouldn't spin with it - as if the bobbin was too loose. Hope this fix works for you too, it was really easy!
Posted on Feb 06, 2009
So what is the solution can we fix it by ourself or do we need to take it to the mechanic
Posted on Oct 31, 2008
My elna 7000 sewing machine does not want to wind the cotton
Not sure of the particular bobbin winding problem you are experiencing. However, frequently the bobbin winder "tire" becomes worn and needs to be replaced.
Elna 7000 Parts
What is the correct way to wind and insert bobbin in elna machine
Jul 20, 2016 | Elna Sewing Machines
How do I wind sharing thread onto a bobbin on a LX-5500 brother sewing machine?
Generally, elastic thread should be hand-wound onto a bobbin. Hand winding allows the elastic thread to be wound onto the bobbin without any stretch prior to sewing.
Feb 22, 2016 | Brother Sewing Machines
How do I thread the cotton down to wind a bobbin?
have you tried a youtube video that shows the bobbin winding for machines like your?
Dec 08, 2014 | Sewing Machines
Xr7700 wont wind thread onto the bobbin
make sure you have pushed the bobbin forward so that the belt will turn the "dowel"
Aug 04, 2014 | Brother XR7700
The machine will not turn the spindle to wind cotton onto the bobbin.
What model Bernina is it? Most operate on a simple system where a rubber wheel on the bobbin winder comes into contact with the handwheel (under the cover) ... the handwheel is disengaged so the needle has no drive.......
Apr 13, 2014 | Bernina Sewing Machines
My bobbin wont wind
you tell nothing, so let me guess
you could have wrong bobbin spool
it may not be inserted properly
your thread is just slipping because it isn't tight on the spool
you haven't engaged the "wind" drive
is the machine running but not winding? have you disengaged the main feed spool?
are you running motor at top speed?
Jan 01, 2013 | Singer Sewing Machines
Needle wont move on its own
First check to see if the machine is in bobbin winding mode. If you are sure it is not in winding mode.... check your motor belt. It's probably worn out or mis-adjusted.
Nov 02, 2012 | Singer 4423 Sewing Machine
Bobbin won't wind on singer 5500 just makes motor noise
the machine probably needs to be serviced
Apr 13, 2012 | Sewing Machines
I can't wind the bobbin tightly enough on my sp10 toyota sewing machinene
it's possible that the machine has a internal problem & that's why you can't wind a bobbin, or it could be warped, the machine needs to be serviced
Mar 06, 2012 | Toyota Sewing Machines
Brother CS 8060 bobbin wont wind...but motor runs
no idea... did you lock thread onto bobbin so it holds to wind?
Jul 17, 2009 | Brother CS-8060 Computerized Sewing...
Sewing Machines Logo
344 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
