Question about Dewalt DC011 AM/FM Radio
DeWalt DW911 Radio/Charger
Stopped working, took apart and found one fuse in small vert. panel. Where is second fuse and where are the two AA batteries?
    Problem Solver:
  • 4 Answers
The second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Posted on Dec 07, 2008
  • fuelpipeline Dec 08, 2008
    also check transformer 120 AC Volt in, 15 Ac Volt out.
    never found 2 aa battery.
    Problem Solver:
  • 5 Answers
If you open the back of the charger, you'll see a small black plastic rectangle. Get a #1 phillips screwdriver to remove the screws, and voila, there are the AA batteries.
Posted on Jan 08, 2009
    Problem Solver:
  • 4 Answers
Never founded 2 aa battery. IN the U.S.
check transformer 120 AC volt in, and 15 AC volt out.
Posted on Dec 08, 2008
  • eizembers Aug 10, 2011
    why dosent the radio work while plugged in if aa batteries are no good.
I have a Dewalt radio (Dw911) that will only play off the battery, not the power cord. I have checked both fuses and found both to be good. It sounds as if this is a common issue but I have found no...
Mine had the same problem .Try swapping the fuses. Although the fuse looked good mine was bad. Easy fix I hope. Going to auto parts store for new ones.
Oct 09, 2010 | Dewalt Audio Players & Recorders
My dewalt dw911 radio/charger works on either mains or battery but wont charge a battery and blows an internal fuse when both are used together
More than likely your internal charger is faulty. Inside your inernal charger unit check the 2 anmp fuse which is white in colour.
Oct 24, 2009 | Dewalt DC011 AM/FM Radio
The radio is not working on the Dewalt Radio/Charger. I am not sure what the problem is. It was working one day, then the next it wasn't.
Replace the AA batteries they are located inside the battery chager. these batts. control the radio and memory stations.
Aug 28, 2009 | Dewalt DC011 AM/FM Radio
My dewalt radio stopped working. I plugged it in, no power. I charged the battery and put the battery in and no power ?
Check fuses inside. Check fuse and connections in plug. If this is a 110v radio there is one on transformer winding.
Jul 17, 2009 | Dewalt DC011 AM/FM Radio
DeWalt DW911 Dis-assembly Problem
look on the back of the radio theres two more screws by the mounts for the cage
Feb 18, 2009 | Dewalt DC011 AM/FM Radio
Dewalt dw911 radio
I had the same problem with the case not coming apart after I took the screws off, but thanks to someone posting a suggestion on this website, I was able to take it apart and take care of the problem. Use a soft mallet and use it around the seam of the radio until it pops loose.
By the way, my original problem with the radio was that it would not get any power at all, whether using the power cord, or an 18v battery. I was able to fix the problem by replacing the fuse located inside the case (250v / 1AMP)......works great now!! Many thanks to all of you who posted suggestions on this great website!!
Jun 05, 2008 | Dewalt DC011 AM/FM Radio
Dewalt radio dw911
Have you changed the AA Batteries, this is often the fault, when they are flat they lock the radio out. HHM Dewalt Service
Nov 27, 2007 | Dewalt DC011 AM/FM Radio
DEWALT DW911
2 screws sunk in at the back left and right. no need to remove speaker screws.
Oct 27, 2007 | Dewalt DC011 AM/FM Radio
Dewalt DC011 AM/FM Radio Logo
2,139 people viewed this question
Top Dewalt Audio Players & Recorders Experts
Gyula Lacz
Rob Beech
Are you a Dewalt Audio Player and Recorder Expert? Answer questions, earn points and help others
