Question about Vestax Pdx2000 Direct Drive Turntable System
Vestax pdx 2000 mkII
After only 2 months of usage on my turntable the fuse blew out. I replaced it and it just blew out again. Could the motor have a short in it or am i not getting the right sized fuse? I bought 2 turntables and the other one works perfect. please help!!!!
Short in power switch! get some switch cleaner spray, (UNPLUG DECK FROM THE MAINS) take off the back and remove the power switch spray switch cleaner into switch (lots) allow to dry (30 mins) put deck back together
Posted on Aug 16, 2010
You should check the fuse on the other turntable to get the correct size, if it persists in blowing you should realy send it back because if you were to use a larger fuse you run the risk of blowing something in the deck, i know its not a great help but its all i can offer
Posted on Dec 13, 2008
4 Suggested Answers
  • 5 Answers
SOURCE: vestax pdx 2000 motor problem
This is a really common fault with this model of TT. I've just repaired a pair of them with the same problem.
You need to remove the bottom cover of the deck then take the round cover off the bottom of the motor assembly. Be really careful with that, delicate sensitive stuff inside. Once you remove the screws use a small flat blade screwdriver to lift it free of the rubbery glue that seals and holds it in place.
Once removed, in the centre of that cover is a small black rubber cirlce about 6mm in diameter that the shaft of the motor rotates on. The problem causing all of that erratic platter movement is with this small black circle.
The solution I found was to use double sided tape to hold this part in place. This serves two purposes. First, to stop the part from moving off its required location, Secondly, to raise the part up slightly from the bracket that it sits on. Layer the double sided tape up so its the around the same thickness as the small black rubber circle. Then place the black cirlcle into its original location bedding it firmly into the tape.
A tiny small dolop of grease on the end of the motor shaft. Replace the motor and bottom covers. Bingo! The decks a-go-go!
Happy mixing!
Posted on Jan 12, 2010
  • 5 Answers
SOURCE: I have problem with tonearm on my vestax pdx 2000
I'd be checking the weight and height settings of the tonearm. Heres a link to the manual for the deck. There's instructions in there about how to setup up the tonearm properly. Don't be afraid to experiment with it. Just remember, too much weight will wear out your vinyl really quickly. Not enough weight will sound like **** and skip easily. Have fun!
http://www.vestax.com/v/info/support/pdf_players_manuals/VOM-PDX-2000E.pdf
gopakumarg43
  • 74666 Answers
SOURCE: My pdx 2000 turntables go backwards randomly
Hello
The fault is to its motor control circuit board. Mechanism alingment also should be checked. contact any expereinced service technician to rectify this problem.
Posted on Mar 03, 2012
Hello
Mar 02, 2012 | Vestax Pdx2000 Direct Drive Turntable...
Hi,my vestax 2300 platter has a slight wobble.i removed the platter and it seems 2 b the motor,can u help?
sliight wobble is normal but if its something you notice i suggest sending it to them to fix it
Apr 28, 2011 | Vestax PDX-2300 Turntable
Does the platter of the vestax PDX-2300 mk 2 fits on the vestax PDX-2300 mk 1?
Hi ezradf ,
i am afraid no it will not fit, the PDX-2300 mk 1 has a bigger fitting then the Mk 2.
Mar 19, 2011 | Vestax PDX-2300 Turntable
Hi, have been given a vestax pdx 2300 turntable and the motor is acting crazy, do i replace motor or is it an internal roblem?
Is there a speed control switch? UNPLUG and try spraying contact cleaner into the speed control. IF that doesn't solve it, then back to the manufacturer.
Jan 11, 2010 | Vestax PDX-2300 Turntable
Pdx 2000 stylus calibration
Hi Misskit , i have a Dual turntable straight arm [Dual is the brand ] maybe you could visit their website and see if there is something similar to yours that you could get some specs from , i think they are still in business they are a German turntable manufacturer . happy spinning
May 24, 2009 | Vestax Pdx2000 Direct Drive Turntable...
I carnt remove the turntable platter can anyone help
The platter needs a drop of oil as the platter and motor shaft is a machined fit, Via brass upside down v as the platter will be reversed ie: a A WITH NO LINE . You can place two plastic wedge shaped blocks ,one on each side of the platter with even pressure and work up.
May 09, 2009 | Vestax PDX-A1MKII Turntable
Re: Power Problem
More than likely the power transformer fried. If so, it will need to be replaced. You might also want to check the fuse. Some of the PDX units have fuses on the rear (where the RCA cables connect)... some don't. I've also seen some that have a fuse on the inside of the turntable, underneath the turntable platter... some don't. If your's has a fuse, see if it has burned out. If so, just replace.
If not, then the only other thing that would affect power on the PDX is the power transformer, and only a qualified service tech should replace this for you.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Aug 09, 2008 | Vestax PDX-2000MKII PRO Turntable
Vestax pdx-2000mkiipro keeps blowing internal fuses
You have a short in your unit, and you will need professional assistance in determining the cause. You might also want to try a different outlet. If it fails, then you'll need to bring it to a service center for repair.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jun 28, 2008 | Vestax PDX-2000MKII PRO Turntable
Open Questions:
See all Vestax Pdx2000 Direct Drive Turntable System Questions
Vestax Pdx2000 Direct Drive Turntable System Logo
522 people viewed this question
Top Vestax Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
Are you a Vestax Audio Player and Recorder Expert? Answer questions, earn points and help others
