Question about Fisher and Paykel GWL11 Top Load Washer
Beeps every second, and won't work at all Fisher & Paykel Excellence 7.5 Smart Drive
Hi, My machine made a clunk yesterdy and stopped working and started beeping. It is not the musical beep so I can't troubleshoot it myself from the manual. It beeps every second and the light sequence is: from the right, spin light is red, next light is yellow, then the short wash light is green, then second to the left from the short wash is also green.
I have taken the middle thingo out and removed some fluff and put it back and switched off at the wall etc and it still won't work. It attempts to fill a couple of times and then the beeping starts.
Any help you can give before I call a technician would be greatly appreciated.
Thanks, Camille
  • Anonymous Dec 14, 2008
    excellence 7.5
  • 72 Answers
The fault is elecrtroic board, as a guess change the electronic board over with an old second hand board
Posted on Sep 25, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 22 Answers
Could something be stuck between outer/inner tub, or down in drainage area. see my post on "eco smart won't drain, smells hot". I took off top and looked between tops--nothing there. Removed pump from bottom and found sock in deepest part of drainage area. Saw another post where a piece of jewelry was wrapped around.
Posted on Oct 22, 2008
  • 46 Answers
Hi camille
can oyu turn the bowl manually if it is very tight then it is most likely the bearingand it will need tobe serviced
cheers grant
Posted on Oct 21, 2008
Hi where can I get a instruction manual for my washing machine
go google and type in -- owners manual for ( make and mode ) fisher and paykel washing machine
if it is available there will be a pdf version down load
Oct 26, 2015 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
Fisher and Paykel Smart Drive Excellence 9 5.5kg won't work at all, no power, no lights, no nothing! help :(
it has fuse boards and the probally burnt out one or more of them ,, if so its cheaper to just junk it .
Mar 29, 2012 | Washing Machines
I have the fisher & paykal excellence 6-5 smart drive model gw609au when i first turn it on the seconds green light is flashing and it is trying to fill up but starts and stops all the time then just...
Hi Damian just read your posting.Your fault on your machine is the out of balance switch is faulty.Do you still require help?Please reply and I can guide you throe the repair of this problem.
Jul 02, 2010 | Fisher and Paykel Fisher & Paykel Washer
Machine stops and beeps every second. Tried various points in cycle. pump appears to work then stops. Its a smart drive excellence 7.5 kg
it sounds like your out of balance switch is open circult.out of balance switch is located under control module.test for continuity on switch.make sure power is turned off first.if u have problems reply 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
F/P Excellence 6.5 smart drive 9
Your inlet valve could be clogged, check this out.............
Dec 26, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher and Paykel GWL11 Top Load Washer Logo
497 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
