Question about Emerson EWF2703 27" TV
Broken remote cant set to component
The remote is broken, and i cant set the channel to component to play a dvd
  • reeze Oct 19, 2008
    same problem....cant manually set TV to component. No universal remotes will work. Is not in "menu" selection either.
  • 374 Answers
On most TV's you can select the source or input by going into the menu on the tv. It is usually under set up although all tv's vary. I hope this assists you and thanks for using Fix Ya. If you need further assistance please let me know.
Posted on Oct 09, 2008
After connecting my ps2 to my Technika 26" tv/dvd combo using a red, green, blue AV component cable, I still cannot find how to tune in a channel to be able to play.
With the composite cable you so not need to retune a channel! You just need to select the correct AV channel from your remote......turn on the ps2 with a game playing and select AV on remote and keep pressing it till you get the Composite channel playing your ps2 game!
Oct 19, 2014 | Televison & Video
I cant get my did/vcr combo to play on my Emerson TV. I all color coded cables attached. Help!
Not enough information for a good reply. Are you sure your tv is set to the correct mode or channel for vcr? Make sure both devices are on, your dvd/vcr playing if you can, and see if the tv on channel 3, channel 4 or channel 91 show that dvd/tape. Otherwise, try checking your remote control, MENU button and look for device options, or INPUT options, on the main menu.
Mar 09, 2013 | Emerson Televison & Video
What channel or setting is used on the TV to play a DVD?
Hi, Channel 3 or 4 might work for older TVs. Most new HDTV's have a mode setting in the menu. (Video 1 or 2 or 3) or (Component 1 or 2). On your remote you may have DVD button. Try all these suggestions, 1 of these will work. You can play with the remote too. Good luck.
Jun 13, 2011 | LG 42LB2R 42 in. LCD HDTV
I played a dvd and now can't get the tv to come on. How do you switch between dvd and television? This is a Westinghouse DVD LCD combo television.
on the remote there are various button at the top to control the functions. these include tv dvd cable etc.
When the remote is set on tv all the functions on the tv work together with the functions of dvd such as play stop etc.all except power channel up channel down etc.
THE REMOTE MAY JUST BE SET TO DVD JUST PRESS TV AT THE TOP OF THE REMOTE OR YOU MAY NEED TO SET IT BACK AND THE PROBLEM IS FIXED!!! THE USER MANUAL SHOWS YOU HOW TO SET IT.
Feb 27, 2010 | Televison & Video
I have a rca dvd recorder+vcr combo drc8320n i want to set up watching/changing cabletv channels on the dvd remote. i have tried buying universal remotes cheap& expensive but they no longer work on my
With cable input connected to "RF in"on rear of unit make sure vidoe input is set to "Tuner". This will show up on the TV screen. Change channels numerically or using up/down arrow keys on DVR remote. Note there is a slight pause between changing channels.You probably will have to "autoscan" for channel setup/etc. If you say your TV set is old; it probabaly is equiped with coax
connection only/set TV channel to "3" or "4". when yot opt to play vcr/dvd it will override your
cable channel selected. Hope this helps!
Apr 13, 2009 | RCA DRC8320 DVD Recorder/VCR
Remote broken cant get tv to play a dvd
have you tried this code? 030 with an RCA remote?
3f159b2.jpg with this or any of RCA's remotes?
Oct 19, 2008 | Emerson EWF2703 27" TV
DS24205 TV INPUT PROBLEM
if you have a sky remote or know someone who does you could try programming it by using one of these codes, try them all one at a time
Sanyo 0159, 236, 073, 100, 064, 174, 185, 367, 039, 245, 246, 398, 241, 572, 583, 037, 132, 182, 244, 191
Jan 05, 2008 | Sanyo DS24205 24" TV
Dvd hookup
No need to play down...many guys are just as untechnical.
Players have three connections. Typically, your tv has similar inputs located on it and plug in goes color to color. Yellow is the video. Red is always the right speaker (on any system). White is the left channel. Insert a known good DVD and press play before you actually do the switchover so you can see it working in the next step. Now...set your TV to component input (it may be TV/Vid on your remote). Your TV manual should tell you how to do this. There may be more than one input...press that button again. It will come through.
If your tv doesn't have these connections, there are similar ones on your VCR...you can 'play through' by setting component input and then getting the VCR to send it on through on a TV channel. Start with the VCR tuning a channel and then switch over to component...Same deal...start the DVD first.
Nov 19, 2007 | Panasonic SA-HE100 Receiver
Mom was hitting buttons and now DVD plays Blue and White!
I think your mom changed the DVD output setting. Using the remote, go to the Setup Menu, then select DVD Setup. Scroll down to the Alt Video Out option. It will either be set to "Component", S-Video, or "Off". It needs to be set to the type output you are using to go from your Go Video deck to your TV. If you are using an S-Video cable, then set it to "S-Video", if using Component cables (Red, Blue, and Green cables), then set to "Component". Otherwise it should be set to "Off".
Hope this helps.
Nov 26, 2006 | GoVideo DVR4000 DVD Player/VCR
Emerson EWF2703 27" TV Logo
106 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
