Question about GE DPSR610GGWT Dryer
Dryer cycle I have a GE dpsr610ggwt. The dryer heats for approx 30 seconds and then goes off for 50 seconds, does this thruout the dry cycle. It does dry the clothes but goes on and off every minute and half, is this normal? machine is 3 weeks old. Any help is appreciated. Joe
  • 943 Answers
HI thanks for your question. your problem might be the venting behind the dryer pull away from the wall to un kink the vent hose. thanks the appliance doc please rate my answer. thanks.
Posted on Oct 09, 2008
Ge dryer timer doesn't work and dryer doesn't heat up. Is there a way to bypass the timer while still producing heat to dry my clothes?
Absolutely not unless you want to risk burning your house down, plus there is HUGE amperage at 220 volts in those wires. All those extra connections go to the three safety devices that are there to prevent accidents. and fires. Just purchase a new timer. They are $30 to $50 depending on the model.
GE dryer timer Google Search
Dec 11, 2017 | GE Dryers
My Electrolux EDV 605clothes dryer is turning but not heating, heating element is ok possible faulty thermistor, dryer heats up when thermistor is unplugged but has an error code of 5 beeps
I think you're absolutely right exhaust sensor is faulty.
The buzzer will give 5 beeps, all program LEDs will flash for 5 seconds and the dryer will continue with the cycle. The warning beeps and flashing LEDs will occur every 30 seconds.
On Timer Drying programs it will run for the time remaining and in Sensor Drying programs it will run for 90 minutes. As the exhaust air temperature can not be sensed the element will be cycled on and off at a preset amount. The cycling time of the element will vary depending on the amount of time remaining.
NOTE: When this fault exists the dryer can still be used but regardless of the Sensor Drying program selected the dryer will use the 90 minute Timer Drying program, Timer Drying programs will use the selected program, and with both types of programs the element will cycle as above. The buzzer will also still be sounding.
If an exhaust sensor fault is detected the buzzer will beep and the Reminder Clean the Filter LED will flash. The LED flashes at different rates depending what is wrong with the sensor -
Fast (4 per second) = open circuit senor, broken wiring or multi pin plug not correctly fitted to the control board.
Slow (2 per second) = Short circuit in sensor or wiring.
The sensor resistance at different temperatures is as shown below.
Temperature (Celsius) Resistence (Ohms)
55 2960
50 3570
45 4330
40 5280
35 6490
30 8030
25 10000
20 12555
15 15880
10 20260
5 26080
0 33870
As you can see this is NTC thermistor with Negative Temperature Coefficient , means if temperature increasing the resistance decreasing.
Dado
Jul 06, 2015 | Electrolux Dryers
My dryer will not heat up Model #dpsr610ggwt what could be the problem?
If this is a gas dryer, it is probable that the igniter on the bottom got drowned. The access panel at the bottom can be removed to expose the igniter for service. There may be water damage to other parts of the igniter assembly as well
Apr 16, 2013 | GE DPSR610GGWT Dryer
The clothes takes hours to dry, they stay damp
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Feb 21, 2011 | GE DPSR610GGWT Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Dryer will not heat
check heating element,,,and thermister
Jul 06, 2009 | GE DPSR610GGWT Dryer
GE Electric Dryers Automatic Cycle won't advance/turn off
check the vent probly cloged or vent hose kinked, or heater is broken.
Dec 21, 2008 | GE DPSR610GGWT Dryer
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE DPSR610GGWT Dryer Logo
116 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
