Blank screen Samsung SyncMaster 172w Monitor goes blank even when computer is turn on.
  • 1 more comment
  • Anonymous Jan 17, 2009
    i plug the monitor in but notheing shows up on the screen
  • aloftin Feb 25, 2009
    I turn on the Viewsonic VA1912wb monitor and it lights up and goes off. There is not a picture that appears.
  • kdcstuart May 11, 2010
    what is a backlight inverter
    Champion:
  • 293 Answers
Well....that my friends, you've got a busted backlight inverter. Need to replaced a new one... Have a nice day!
Posted on Oct 10, 2008
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
Samsung Syncmaster 943b light blinking but screen remains blank, tested cables, message 'test good' flashes on screen then goes blank again.
try to connect monitor with other computer, this way u will confirm weather the fault is in monitor or in computer. if it is in monitor, check for bent pins in connectors which connecting computer & monitor, firmly connect both ends of connecter & tighten the screws. if problem not solves then u need to replace main board of monitor.
Aug 25, 2011 | Samsung SYNCMASTER 943B 19" LCD Monitor
Samsung SyncMaster 223BW monitor screen goes blank
You should get three years warranty, if you can locate your receipt and contact them direct they will sort it for you :)
Good luck
Jul 25, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
My samsung syncmaster 920nw picuture goes blank after a period of a couple of minutes. If I turn the power off and then back on the picture re-appears but goes off again. It is not he pc since it works...
If you get a flashing screen which show your screen for few minutes and then goes blank it may be an issue with the Monitor.
Try to restart the computer and go to BIOS setup screen. If you experience the same issue in BIOS then the monitor needs a repair or replacement for sure.
Jul 19, 2010 | Samsung SyncMaster 920NW Monitor
Dear Sir, I am facing problem with my Samsung LCD monitor, when I switched on my Computer it shows the bootup screen, after booting the LCD screen goes blank, when i turned off the monitor and again turned...
yes turn on the computer and keep pressing F2 contineulsy immediatly after display observed then menu will be come then highlight on last good known configuation and press enter problem will be solved
Mar 05, 2010 | Samsung Syncmaster 730B 17" Flat Panel LCD...
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
Could be a power issue. If it doesn't show anything at all then that may be the case. It may also be the display itself. It would be a costly repair so you might be better off finding a new monitor.
Sep 16, 2009 | Samsung SyncMaster 920NW Monitor
Samsung 204B random blank screen
I too have a dual monitor Samsung SyncMaster 204 setup. My monitors started flickering, then a week later had turn on problems like your describe. I found a fix on this fixya website and followed the fairly techie suggestion. It worked. I wrote up a .pdf set of instructions so others might also benefit. Hope this helps. Doug
Feb 07, 2009 | Samsung SyncMaster 204B 20.1" LCD Monitor
My monitor goes blank repeatedly
1. First u can check any dry points in power supply board and controlling circuit.
2. check all connectors (connected properly)
3.To replace front pannle Micro switches.
Oct 04, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Blank Screen while Green LED is Blinking.
It's because I accidentally plug the cable to the built-in graphics card port. Now I connected it to the right one and my monitor is working great!
Aug 19, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Computers & Internet Logo
910 people viewed this question
David Payne
David Payne
