I have a sony projection tv model:kp-57ws500. The picture went out and i get 5 blinks fromt the front led. How can I fix it and where can I buy the parts?
    Genius:
  • 1,139 Answers
Hello agoche,
The problem you are experiencing is a power supply problem. If the sound is affected then the problem is that either a fuse has blown or the HV shutdown circuit has activated due to excessive current flow. If the sound is not affected this means that your TV may have a problem in the HV section where the IHVT or the HOT has malfunctioned and thus the High Voltage is not working. Now I have also seen in these type sets problems with the convergence amplifiers causing problems with the power supply.
To fix this problem you must first isolate what is wrong with the TV. To isolate the problem you will need the schematic for the TV (even though you have the blinking LED this just tells you that the set has a power supply problem)
Once you have a schematic you can then use a multimeter to tests the various test points as located in the schematic, compare the measured values with the values on the schematic and note the erroneous measurements. Whichever section is not giving you the proper readings you should concentrate on that section to find the problem.
One place that I buy parts from is:
http://www.electronix.com
Now I must say that if you do not have a background in electronics I would suggest that you get a qualified TV repair person to do this work for you, because you will be dealing with dangerous voltages that can kill you if you make a mistake.
I wish you well
Thank you,
Shuttle83
Posted on Oct 09, 2008
    Scholar:
  • 62 Answers
With this particular model, 5 blinks means white balance failure (Not balanced)
Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
I think this might be one to call a quailified repairman on.
Hope this helps,
Chad
  • 2,326 Answers
The 5 blinks means:
1. Video OUT (IC7101, IC7201, IC7301) is faulty. (CR, CG, CB Boards)
2. CRT drive (IC309) is faulty. (A Board)
3. Screen (G2) is improperly adjusted.
To repair this failure you should be familiar on the use of a multimeter, soldering/desoldering iron.
  • 749 Answers
Sony Customer Information Services Center
1-800-222-7669
or visit the Sony Web Site:
www.sony.com
For an accessory or part not available from your authorized dealer, call:
1-800-488-SONY (7669)
Make sure the projection TV’s power cord is connected securely to the wall outlet.
❏ Push the power button on the front of the projection TV.
❏ Check to see if the TV/VIDEO setting is correct: when watching TV, set to TV,
and when watching connected equipment, set to VIDEO 1, 2, 3, 4, 5, 6 or 7.
❏ Try another channel. It could be station trouble.
❏ The Parental Control feature is activated
❏ If your projection TV does not turn on, and a red light keeps flashing, your
projection TV may need service. Call your local Sony Service Center
Sony rear projection screen is red then tv shuts off
Can be 1 of 2 things. 1st the red tube just needs the voltage to it turned down. In the front of TV (you have to remove the lower front half of TV to access it) is a plastic square with 6 knobs. The from left to right top knobs control focus for blue,green red. The bottom knobs control voltage to each tube in same order (so lower right knob for red) turn SLOWLY to left to reduce voltage until excessive red and lines go away. If you over turn left or right set will turn off. If that does not fix it or if lines reappear then option 2 is that red picture tube is failing outright and needs replacement.
Jan 29, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500 57 in. Rear Projection Television
THE LED ON THE FRONT OF THE SET SHOULD BE BLINKING IN A SERIES OF BLINKS THEN PAUSE AND REPEAT THE SEQUENCE. IN ANY CASE IT NEEDS TO BE SERVICED BY A SONY AUTHORIZED SERVICER.
Dec 27, 2008 | Sony KP-57WS500 57" Rear Projection...
Major problem with sony kp-57ws500
BTW if you appreciate the help I have given you, please rate me! Thanks!
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Picture is all red and led blinks 5 times
Most likley bad tube have replaced alot of them on this make and model.
Sep 02, 2008 | Sony KP-51WS510 51" Rear Projection...
Six (6) blinks on the Timer/Standby led
6 blinks means lamp thermal fuse blowing, replace thermal fuse.
See here
Aug 30, 2008 | Sony KP-57WS500 57" Rear Projection...
KP-57WS500
I had this problem and at the same time I was getting blue tint. When the blue got darker, this would happen, Adjusted the voltage on the guns (3 screws in the front - lower panel off) and the blue went away and it stopped turning off. But later, it would start all over again. Same procedure, same fix.
Jun 24, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-57WS500
· Sony Picture tube recall
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
Feb 11, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-57ws500
You have a bad green picture tube. If you have warranty coverage good, if not then forget about it. Get a new TV.
C-Dog
Jan 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony kp-65xbr10w led light blinks 5 times
i have a sony tv model kv36fs17. led flashes 5 times. tv works but no red color. would could be the problem? thanks
Jan 23, 2008 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-FX432M91 TV 10 blinks
my sony kp-fx432m91 has a 10 blinks problem. it has no pictures but has sound that goes off after 5 seconds please advice on what to do.
my email address is drbonnyb@yahoo.com
Oct 31, 2007 | Sony KP-FX532M91 TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
