Question about Canon PIXMA MP150 All-In-One InkJet Printer
Message 'waste tank full' what does this mean Waste ink absorber is full - is my message on my Canon MP150. I was told it is cheaper to get a new one than try to fix it. I do not even see where the part is. I am told that it will probably just quit working one day and today I have a major papaer jam under the ink cartridge. This has never happened and I have used it daily for 3 yrs!
    Problem Solver:
But every times u do this 2 step solution!!!!!!!!!
Posted on Oct 12, 2008
  • chen hong
    chen hong Oct 12, 2008
    Better u buy Canon Pixma iP1300.
Important to understand there is no waste tank and certainly no sensor. There is an area under the vacuum pumps where waste ink collects and is hedged in by walls of foam. The message must be created by a count on the number of times the cartridges have been purged so the key thing is to reset this counter as well as mopping up the ink. Not tried the solution 1 method, mine responded to pressing the color scan button !
Posted on Jun 03, 2009
  • 70 Answers
"It´s very simple people.
Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
That´s all."
Posted on Oct 09, 2008
When i used tried to print a document, there shows an error stating that the waste ink absorber is full. How can i over come this problem
Hi!
Here is your solution ... to solve you problem follow it....
http://printertools.blogspot.com/2007/10/canon-mp150-reset-codes.html
This just resets the error message - it does not remove excess ink from the waste tank! Good Luck....
Sep 07, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The Waste Ink Absorber is full. Will no longer print. Can this be fixed?
To solve your problem please contact this website ...
Good luck...
Sep 06, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Sign showing Waste Ink Absorber is almost full. What should I do?
It means that your well used printer has reached the point that it needs maintenance: your printer waste ink pads and reservoir need to be removed and cleaned/replaced AND the internal counter reset.
It is 'officially' recommneded that you take your printer to Canon prnter service centre but I think that buying a new cheap printer would be a cheaper option!
You an also try to maintain and fix the problem your printer yourself: resetting the counter is 'relatively' simple (by going to the Service menu) BUT YOU MUST clean the waste ink pads and reservoir or RISK A MAJOR INK OVEFLOW DISASTER.
If you want to do it yourself, just Google for 'MP150 Waste ink counter' ....
Hope it helps!
Jan 07, 2011 | Canon PIXMA MP150 All-In-One InkJet...
The waste ink absorber is full
To reset your Canon IP1000 just simply pull out power cord then press-hold power button, while holding power button insert back power cord. You will notice that the power button indicator lights up upon inserting power cord. then you may release power button and start printer. That will solve your "The waste ink absorber is full" message.
Downside is: you may have to do this frequently if your printer looses power. You will understand what i mean.
Jan 04, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Our Canon Pixma MP150 is showing an error message E5 and previously E3. Can you tell me what these mean please.
here are the error codes for your printer
E2 - No paper (ASF)
E3 - Paper jam
E4 - No ink
E5 - The ink cartridges are not installed or a non-supported ink cartridge is installed , or the ink cartridges are not installed properly
E8 - Waste ink absorber full, or platen waste ink absorber full «ОК»)
E9 - The connected digital camera / video camera does not support Camera Direct Printing
E14 - The Ink cartridges whose destination are wrong
E15 - Ink cartridge is not installed
E16 - Ink remaining is unknown
E19 - Failed to scan head alignment sheet
E22 - Carriage error
E23 - Paper feed error
E24 - Purge unit error
E25 - ASF(cam) sensor error
E26 - Internal temperature rise error
E27 - Waste ink absorber full or platen waste ink absorber full
E28 - Ink cartridge temperature rise error -
E29 - EEPROM error
E33 - Paper feed position error
E35 - USB Host VBUD over current error - USB
E37 - Abnormal motor driver error
E40 - Other hardware error
E42 - Scanner error
Oct 16, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer flashing E8
E8 means Waste ink absorber full, or platen waste ink absorber full so reset ink also check the waste ink pad and clean
Aug 18, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
Sep 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA MP150 All-In-One InkJet Printer Logo
178 people viewed this question
old marine
old marine
