Question about GE Refrigerators
Hi Guys, I have a GE Profile Frig: PSF26NGTDBB Serial # SL416129 This AM the softdrinks seemed a little warmer than usual. We checked the digital temperature inside the frig compartment and the freezer was at 4 degrees instead of 0 and the frig side was 42, normally 37 degrees. WE pushed the Turbo Cool button and the green led light came on. We left and came back an hour later and the Turbo Cool led was off. Please help...Sunny
  • 943 Answers
HI thanks for your question. the problem is either that the fan in the freezer is not working, or the fridge is frosting up, or the coils at the back of the fridge are dirty. first clean the coils .it could be you problem. thanks the appliance doc please rate my answer . thanks.
Posted on Oct 09, 2008
GE TFX22P Refrigerator Evaporator Fan
Fun run as long as the compressor runs and you do not need to worry about it. the only thing you need to verify are the temperatures in the refrigerator and and freezer compartment: below 40-F, and below 0-F
if temp ok, do not wory about it.
Aug 18, 2014 | GE Profile 21.6 cu. ft. Side-by-Side...
On our 15 year old GE Profile TPX27PF frig the freezed defrosted (system check "FF") and the "warm" light came on for the frig. This has happened several time. After each episode the frig corrects...
Probably the start relay and capacitor....
Check the last tip...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile PSW26PSW. I bought it new in
If the condensor is dirty, the frig will have to work like the dickens to to stay cool. The condensor coils are either under the unit, or on the back. the newer units tuck them neately under the unit and a good toilet brush, degreasser soap, like "Dawn" works great. If she still is heading south, My first guess would be the compressor, or the thermostat. Try the Condenser coil cleaning first. Lloyd
Jun 01, 2010 | Refrigerators
Temp set at 5(as always) but food in the refrigerator is freeezing. Ice maker and water distpenser do now work. just started happening.
Try unclogging the drain line for the freezer. What seems to be happening is your refrigerator is working too hard to keep the temperature that it reads inaccuately. Usually a light defrost will do the trick , sometimes a longer defrost or one using warmers...don't be too tempted to use anything like a hair dryer for safety reasons.
Make sure you keep your frig door closed and use the frozen food in the frig to hold temps down.
Good luck.
Mar 28, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile temperature going up and down
One of four problems,
1: this box has two sensors in the freezer... one on the top of the evap and one on the bottom left side of freezer cabinet (little small round white things) in the back lower portion of the freezer. These have been know to go bad and cause this problem.
2: you have a defrost problem caused by a bad main board or bad defrost heater.
3: you have a evap fan going bad on you, quits when frig gets to right temps. in other words the fan doesn't like the extreme colds,
4: door gaskets are leaking air around doors.
Oct 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile is Buzzing
Checx the wire connection and the way u food is inside ur frig. Maybe something is not at the right place!
Sep 13, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile side by side freezing everything
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=219577
thats what you need its not that hard to put together
thats the kit that allows air into the fridge and its allowing too much, before you order this  go to the back of the fridge and take off the silver panel  with about 10 screws take off the control board take off the wires and it has clips on each corner of the board get needle nose pliers and squeeze the white plastic that extends out of the clips and pull the board towards you got to do that for all 4 corners once you do that check on the back of the board for black smudges and burning smell if there is significant black smudge or burning smell you need to oder that but im 97% sure you need the inlet assembly
its located in the middle upper part of your fridge
Jun 08, 2009 | GE Profile PSS26NGS Side by Side...
GE Profile PSC23MGNA too cold on frig side & icing up on freezer side
Check your thermostat if it is still functioning well.
May 02, 2017 | Refrigerators
Refrigerators Logo
377 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
