Question about Whirlpool Washing Machines
I have a whirlpool top load washer, when I did a load of wash last night I found water at the bottom of the machine. all the hoses are fine - any thoughts as to what the problem might be?
    Problem Solver:
  • 5 Answers
Sounds like the drain pump filter look in the manual it will tell u where it is should b easy 2 get 2
Posted on Oct 09, 2008
Clean water is dripping into the washer constantly from the intake hose. When I come home at night, there is water laying in the bottom of the washer. I can see the water dripping from where it normally...
There is an water inlet valve that controls the amount of water that enters the washing machine. Just like a faucet for your sink. It needs to be replaced and can be found an any appliance part supply.
Jul 15, 2010 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Water leak at the bottom?
you may have hose leak, or you may need to replace the water pump.. also check the hoses from the water supply lines. water may be running down behind the hoses
Oct 11, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Whirlpool Ultimate Care II Quiet Wash - Wash Cycle not holding water
Since your washer worked fine while in Germany and now is exhibiting this problem at your new home, you may want to double check how it was installed. I suspect you may have a problem known as "siphoning". The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
This could be a simple situation where the drain line on the washer is not installed correctly. There are minimum height and length requirments on the drain line. In addition, make sure the stand pipe you have the drain hose inserted in has a proper air gap to allow draining. All of this is explained in the link provided.
I hope this information is helpful to you. The majority of the situations arise from improper installation and is not an operaitonal problem with the washer. If, however, you double check everything and still have problems, please post back and let me know.
Sep 11, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Old whirlpool washing machine won't run.
if no lights suspect main control bd remove rear screws in top panle remove top by sliding towar back control is along rear
Jun 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Washer overflowwing
I had the same problem. My whole basement flooded. Inside the back (you can see it thru a small hole 1/2 way up on right) a small white hose connects to the water shut off collection area. This hose carries the water from the tub to the collection area and tells the machine to cut off for the size of load selected. Mine had come undone and so the machine could not sense it was full and the water poured all out the bottom. I simply removed the small gray panel at the bottom on the back and reached up inside to reconnect.
Jan 26, 2008 | Maytag Performa PAV2200
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
