Question about Sony Playstation 3 (PS3) Console
My ps3 Start Up problem
Every time I start up my ps3 it makes sounds and no image in on my t.v screen. i can still here the click sounds but no image..what happened????please help!!!!
  • 3 more comments
  • Anonymous Oct 10, 2008
    I have the 80gb model. No picture appears on the screen. I have already tried resetting the video output, but that did not fix the problem.
  • pEesthree Oct 10, 2008
    WHEN I PUT MY PS3 ON IT FREEZES BEFOR I CAN PUT A DISK IN
  • DaDoctior Oct 10, 2008
    I turn my playstation on but get no response, except for the green light on the console, and the sound off the fan.
  • pete_roehr Oct 25, 2008
    I have the same problem!! it happened yesterday.. the green light is on and the fan is running silently, but nothing on the screen. some sort of failed startup or something.. i was playing dead space for god's sake!
  • terrster03 Nov 07, 2008
    After the PS3 telling me to restore my PS3 for no reason, I managed to do it and after that I get this damn problem.
I turn my ps3 on and the green light flashes and switches off without we touching anything nothing appears on the screen either??????????????/
Posted on Oct 10, 2008
I have just recently got it to work! Turn off your PS3 about 3 times, approximately 5 minutes in between each time and after that it should work. It did for me.
Posted on Nov 07, 2008
2 Suggested Answers
kriskogarcia
  • 98 Answers
SOURCE: ps3 start up promlem
so if you have ever had your ps3 connected to HDMI (HD cable) before, and your forgot to change it back to the normal cords that came with the game (yellow, white, and red) then you will have to connect it back up to the HDMI and go to the Display Settings and change your video output to the one that came with the ps3 (which looks like just one yellow in the settings.) then after you do that then the screen might go black if your HDMI and regular cable are on a deffirent channels, so you turn to the channel that the yellow white and red cable needs to be to, then it will show the screen and ask you if you want to leave it at this setting with this video output/cable then you say yes then your good to go.
Posted on Oct 11, 2008
How do i use the built in webcam on my asus computer
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start control panel administrative tools ,computer management ,device manager scroll down
or click start right click on computer select properties device manager scroll to image devices
image devices you could see a yellow question mark?
right click to reinstall drivers or update driver
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select
the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
hope this helps
Aug 06, 2012 | Computers & Internet
When playing a game or dvd, my Playstation makes a ticking sound like somethings jammed in it. It's possible my daughter stuck something in there and messed something up. It'll play and as time goes on the...
PS3 Clicking noise is associated with the hardware aspect, so that's your starting point it may come from the PS3 fan clicking, so do check out the fan if there's something that might have got stucked in between. Clogs from too much dust or dirt may also cause PS3 clicking sound.
PS3 clicking noise may also come from the hard drive. The hard drive are a bit noisy because of the mechanical parts and moving drive head when reading and storing data. Again, if the noise level is very minimal, there's no worry. PS clicking noise fro the hard drive that becomes too audible may signify that the hard drive is having mechanical problems and may soon broke down. At this point you may want to backup any data you have
I hope this helps you.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
My ps3 says, cannot start, the correct hard disk and whines
yes this should solve your problem. however this will void any warranty so if there is still warranty then send it off. otherwise replace it and the problem should be solved
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
Ps3 will not start up. no display
sounds like the resolution is not set correctly on your tv or your ps3 settings. make sure they both are set to 720i to start, if you have a HDMI cable, that should be the min resolution your tv will do.
Find out the max resolution your tv can do, and set the ps3 to output that.
720i is a good place to start.
Jun 28, 2009 | Sony Playstation 3 (PS3) Console
No start up sound and no image display
good day! you mean that you no longer can''t hear any start up sound every time you are turning on your gadget? you try clicking on the settings if there is because there are some instances that the tune is muted. in regards with the blank screen photo, there might be something that is obscuring the image screen. for more inquiry, please keep me in touch. thank you!
Apr 10, 2009 | Canon PowerShot A75 Digital Camera
Playstation3 startup problems
contact sony at 1800-345-7669 then can repair it for you your memory chip could be fried and that is where menu screen data is located
Jan 04, 2009 | Sony Playstation 3 (PS3) Console
Start up screen
have you tried it on anoother tv?
you see the cable connecting from the tv to the ps3?
make sure the yellow onw is working properly
Yellow=Viewing
Red=Right Sound
White=Left Sound
Dec 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 start up promlem
Oct 09, 2008 | Sony Playstation 3 (PS3) Console
My PS3 wont start up. when i turn it on i get noting no sound or image .
Check your HDMI (looks like USB connetion) Connection or your Composite video connection (yellow, red, white connections.) Make sure they are correct and tight on both your TV and PS3.
Most common connection to use 1st is the Composite video connetions. Yellow is your Video display; Red and White are your Sound!
Good Luck.
Sep 26, 2008 | Video Game Consoles & Games
Sony Playstation 3 (PS3) Console Logo
470 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
