Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Whirlpool side by side GS6NBEXRO01
The water filter on the refrigerator won't pop out.  I push on the button but, it won't press in.  Never had this problem before...any suggestions?
Thanks!
    Problem Solver:
  • 5 Answers
Did you turn the water filter to unlock it?
Posted on Oct 16, 2008
The Whirlpool refrigerator was included in my new house. My user manual does not give any instructions on how to change the water filter. Model is ED5FVGXWS02.
take the panel off of the bottom,some of these have a button you push and it pops the filter out or you turn it counter clockwise to remove the filter and then install the new one same way the old one came out.yours has the button just push the button in and it will pop it out the new filter is part EDR3RXD1
go here look at part # 11 that's the filter and # 24 is the button you push
https://www.searspartsdirect.com/model-number/ED5FVGXWS02/1198/0165000.html?searchType=modelSearch&q=ED5FVGXWS02&searchTerm=ED5FVGXWS02
Sep 27, 2017 | Whirlpool Refrigerators
Filter button pushed in and wont release filter or pop back out
Make sure the filter is pushed in all the way, this only happens when the filter is not installed all the way.
I hope his helps
Oct 27, 2013 | Whirlpool ED5VHGXM Side by Side...
Looking for water filter to be replaced. The red light is on and I can't find filter.
On a Whirlpool you can check the bottom front black vent piece, filter cover looks like a half-moon shaped cover. Its under the freezer side. There is a thumb-sized black push button next to it which will 'eject' the filter. Push on the black button and the filter pops out
Dec 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do you change the water filter?
Which Whirlpool model do you have?
I know the ED5KVEXVQ has the filter in the grille nearly centered on the freezer (left) side of the unit. This is the P2RFWG2 or 4396841 filter. Push the button until the filter pops out. Take the cap of the end of the filter (the side that was even with the grille) by twisting counter-clockwise. Take the new filter out of the box and put the cap on the appropriate end (twist clockwise). Take off the red caps from the other end. Insert the filter into the opening with the cap to the outside and press firmly until it clicks into place.
The other common Whirlpool refrigerator filter is the 4396710. This installs the same way except it doesn't ship with a cap that you need to remove on the one end.
I hope this helps.
Dec 13, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
How do you get the water filter out of refrigerator so you can replace it
Without knowing your particular model number, I checked and most 25 cu.ft. side by sides have the water filter in the grille. You just push a release button and it pops out. There is a cap on the filter, do not through it away as you will need it on a new filter. Also ensure the O-ring protective covers are removed on the new filter prior to installing. You can run the water dispenser without a filter as well. Here is a link to the PDF for one type of 25 cu. ft. Whirlpool side by side.
http://www.whirlpool.com/assets/pdfs/product/ZUSECARE/GS5VHAXWA_Use%20and%20Care_EN.pdf
Jul 17, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
How do I change the water filter in the refrigerator?
down in the front grill at the bottom of the fridge you will see the filter and just the the left of it you will see a button. push the button in and that will pop the filter out a bit. pull it out and put the black cover that was on your old filter and put on your new one. then just push it in
Mar 26, 2010 | Whirlpool GC3NHAXVY Stainless Steel Side...
Water filter won't come out when I push the button
Push button? It should be a turn to the left to remove if it is a whirpool located at the bottom. These are twist out not push to release. The only push to releases are made by electrolux.
Mar 07, 2010 | Whirlpool ED2FHEXN Side by Side...
Where is the release button for the whirlpool gold conquest water filter?
your filter either has a release button directly next to the filter within the kickplate. teardrop shaped button you push, or the only other filter hpusing requires that you twist teh filter out by turning counterclokwise it to is located within the kickplate under the refrig door
Mar 10, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
150 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
