Question about Western Digital Caviar WD2500BB 250 GB Hard Drive
SATA hardrive not being detected
Just wondering if you solved the prolem of your second SATA drive not being detected whitn XP as I am having the same problem?
The drive is a Western Didital Caviar Green 750 GB.
Thanks,
RC
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - possibly there's not enough power from or PSU or something's wrong with the cables.
Posted on Nov 30, 2008
I cannot connect SATA HDD
SATA HARD DRIVE - XP INSTALLATION
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Feb 26, 2013 | Computers & Internet
Hi there i have a hp motherboard that is not recognizing anything to do with drives it is a sata setup and have changed the cables with no change in recognition do you know whats wrong with this board...
You can try by taking out the bios battery first it might of died on you theres also a ultimate boot cd you can find and download for free i had this problem before put on usb if you get to the bios screen see if it detects your cd drive once the batterys are out hold power button down for 15 to 30 seconds this should at least give you basic function drivers and make sure you have it detect your hardrive and move boot device to cdrom first then have windows cd in computer on reboot windows xp without sp3 probly wont detect a sata drivenot sure might have to use vista
Jan 25, 2011 | HP Compaq Presario F500 F700 and G6000...
Hello, Where could I find a driver for WD5000KS SATA? I am trying to upgrade my desktop PC to Win 7 but when installing it, the setup could not detect the SATA HDD and asked me to load the HDD driver. ...
Check in your BIOS,first make sure the SATA controller is set to native mode and not RAID, and secondly that the BIOS can detect the drive, if the drive can't be detected by the BIOS then it's because the drive surpasses the boards drive size limitation.; If this is the case there is a chance a BIOS update may fix it but it's not guaranteed it will.
Jan 05, 2011 | Western Digital Caviar SE16 (WD5000KS)...
Can't load xp on hp xw4300. Has sata hdd & ide dvd drive. Xp can't detect hard drive and if press f6 it says there is no floppy drive
replace your cables and try again. if unsuccessful locate your hardrives manufacturer ie: maxtor software MAXBLAST , download the hardrive software utility and ``0 fill`` your hardrive to factory default.
Nov 05, 2009 | Cars & Trucks
Trying to format the hard drive but can not find device drivers or partitions
If you have access to another computer, download Gparted BootDisk
This will boot on any system and allow the format assuming the hard drive is actually working
Oct 12, 2009 | Computers & Internet
External hard drive enclosure help
Is it a small disk (about 3 inches wide) or is it a larger one (about 6 inches wide)? Problem is, XP don't have the drivers to "see" SATA (Serial ATA) laptop drives. Try upgrading to Service Pack 3 to see if it solves the problem.
(Don't forget to Rate me, after you fix the issue).
May 16, 2009 | Dell Inspiron 6400 Notebook
Hanging on detection of drive when installing Windows XP
Installing Windows XP on a SATA hard drive is not a straight-forward task as Windows XP does not recognize the SATA drive. In order to install operating systems such as Windows XP on SATA drives, the latest SATA drivers are required.Download SATA drivers for the motherboard from the website and integrate them with the XP installation CD using software such as nLite. SATA drivers can also be installed as third party drivers; you will be prompted during the installation process. Without proper SATA drivers, installing Windows XP on a SATA hard drive is not possible as SATA mode would have to be disabled in the BIOS to continue with the installation.
Installing Windows XP on a Serial ATA hard drive is not an easy task, because the system does not recognize SATA drivers at startup. Windows XP Pro SP2 fares a little better with SATA drivers, but here is what can be done in cases where the driver is not recognized.
Mar 31, 2017 | Excelstor Technology J880 Hard Drive
Drive SATA 3.0 Gb not detected by msi 7060
3GB Sata driver? i dident know there existed so smal drivers
Anyway, if your bios dosent detect the driver u probably need to update the bios drivers.
Go to MSI site:
http://global.msi.com.tw/index.php?func=proddesc&maincat_no=1&cat2_no=&cat3_no=&prod_no=158
Instal LIVE UPDATE and let msi check you computer for laterst drivers u need to instal
Nov 20, 2008 | MSI 661FM2-LSR Motherboard
Install windows XP on toshiba satellite U300
Hello
The windows Xp installation doesent find your hardrive because you have a sata drive. you need to adjust the settings in the bios so the sata drive appears as a ordinary IDE drive(ide native) or something like that. search in the bios settings.
A other way is to burn a new winxp cd with the Toshiba Satellite U300, sata drivers.
download the http://www.softpedia.com/get/System/Back-Up-and-Recovery/Barts-PE-Builder.shtml
and download the toshiba harddrive drivers and creat a new cd.
but the simples way is to make the change in bios.
good luck
Aug 18, 2008 | Microsoft Windows XP Professional With...
Windows XP will not pickup my 2nd hard drive (intermittent fault)
most likely it is getting ready to crash, remove your files and replace the HD very quickly.
Rmatheson@wowway.com
Aug 16, 2008 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Western Digital Caviar WD2500BB 250 GB Hard Drive Logo
179 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
