Question about Whirlpool Refrigerators
Whirlpool Model AD40USL5 Has quit pulling out water. I cleaned the coils but if sounds as if the compressor starts and then cuts right back off
  • 943 Answers
HI thanks for your question. so you did clean the coils ok. i think the problem your having is with the relay. check that. try and turn off, for a few hrs, the compressor is very hot . let it cool off. and try again. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
I have a whirlpool side by side refrigerator model number gd5phaxlq00 the fan and the compressor sound like they are working but my fridge defrosted by its self yesterday and now its warm inside we cleaned...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 26, 2011 | Whirlpool Refrigerators
A few days before we discovered that the fridge wasn't working properly, I heard intermittent clicking sounds. The motor at the back and bottom??(not sure exactly where) of the fridge sounded like it was...
IF YOU HEARD THE UNIT CLICKING FROM THE BACK AND THEN A FEW MINUTES LATER DO IT AGAIN MOST likely you have a bad start relay on the compressor and the overload device on the compressor is kicking out... whirlpool is known for this particullary problem and it normally is a easy fix... go to www. repairclinic.com or apdepot.com and you should be able to enter you model number on one of those sites and your looking for the compressor relay ....
to varify it is bad and prior to buyiong pull it off should be 2 maybe three wires in some cases and shake it...if the relay rattles like something broke thats your problem.... also unplug the unit the more it trys to start with the bad relay you could eventually damage the compressor if it has not already..... good luck
Jan 03, 2011 | Whirlpool ER6AHKXPQ Top Freezer...
Hi I have a 2006 Whirlpool GC3SHEXNB03 side by side frig, the "gold" model. The freezer was not cooling well last night. I pulled the panel in the bottom front to access the coils. They had a lot of hair...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Oct 10, 2010 | Whirlpool ED5VHGXM Side by Side...
Compressor wont run .How do I check it? whirlpool model #ed25dqxvw03
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then checkout the last two tips.
heatman101
Sep 21, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The freezer side quit staying cold today. No
heatman101
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
ZFSB26DRESS water runs warm and freezer not staying cold.
It sounds like the condenser coils , the coils by the compressor , need cleaned badly . This (and the compressor cooling fan) , can cause the compressor to cut off on overload (due to the heat) , thereby not circulation refrigerant thru out the freezer coils .
The water line goes from inside the freezer door ( cold ) , under the refrig ( warm ) , then to the inside refrig water reservoir ( cold ) . After that , you should get cold water , until the reservoir is drained of cold water .
Nov 19, 2009 | GE Monogram Side by Side Refrigerator
Have a whirlpool side by side refriferator estate model. Freezer won't get cold. Cleaned off underneath,fan is turning, Unplugged for awhile and plugged back in. Keep hearing clicking noise coming from...
Plastic box you're referring to contains the start components for the compressor. The clicking sound sound you hear is the protective overload shutting the compressor off because it won't start.
Two possibilities
1. The components inside the plastic box (cover) are defective and need replaced. You can remove them, by snapping off the cover and pulling them straight off. Most appliance parts houses will be happy to test them.
2. The compressor has failed internally.
Note: In my personal experience when dealing with whirlpool Estate models, 99% of the time it has been a failed compressor.
Oct 28, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Oct 03, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
PULLED FRIDGE OUT, REMOVED BACK PANEL, EVAPORATOR
Yes , motor is bad . May not start , next time cuts off . The fan in the back by the compressor , is called the condensor fan motor . I would suggest cleaning the coils in front at the bottom , of dust , lint , pet hair , etc , before replaceing the fan motor . Also , clean the fan blade before reinstalling the motor .
Sep 11, 2009 | Refrigerators
Whirlpool Side by Side Fridge Not Cooling
Here's the sequence: First, the unit must be ice free. This happens after power down for about 2 days. If the compressor is clicking, power off for 15 minutes. While waiting....
Clean the condenser coils.
If a mechanical thermostat, does it click when you turn it from off?
Locate compressor in back of unit. Find largest pipe. Power on.
Pipe should frost over for about a minute and then either dry out or form ice on it. If frost stays, you need refrigerant.
If compressor is not running, it could be thermostat, defrost timer (find this little gem in the back of the refrigerator and turn the stub shaft about 1/3 way around...does this change anything?) If the timer is bad...replace it.
Compressors generally don't fail from long run cycles.
hope all this gets you somewhere.
Nov 18, 2007 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
157 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
